back chair rails
Howard Pollack
Hi folks,
How does one make a curved top chair rail, steam bend or cut with bandsaw? If steam bend, can you keep mortices for back slats lined up with the back seat rail (also curved)? Thanks.
-Howard
back chair rails
Howard Pollack
Hi folks,
-Howard
Re: back chair rails
William Duffield
What style of chair are you interested in building? There are almost as many construction techniques as there are styles of chairs. Also, please define what you mean by the "back seat rail" and "top chair rail." For many styles of chairs these terms might be interchangeable.
Howard Pollack
I'm interested in building a few outdoor chairs with curved slatted backs. By "top chair rail I mean the horizontal rail that is at the top of the chair (about shoulder or mid-back height) but "back seat rail" I mean the rail that is at the back of the actual seat. Thanks. -Howard
Larry Barrett
Howard - you do not say what type of wood you are planning on using. Also, your question seems to imply that you want to chop or cut slat mortises prior to steam bending.
Here are some thoughts on steam bending, based on my experience. First, you are likely to have success if you use hardwood, and failure if you plan to use softwood. I have had good results using oak, hickory, cherry, and walnut. Although I have not tried it, from everything I have read softwoods cannot be steam bent successfully. For outdoor use, white oak would do well. Depending on the amount of bend, you will have best luck with riven white oak, or at least sawn to prevent runout. Green wood, or air-dried will give better results than kiln dried. Second, I suspect if you chop the mortises prior to steam bending, you will experience failure. Mortise after bending; it is not hard to do if you keep your stock square so you have a way to hold it firmly on your bench for moprtising. Do any shaping of the rail after bending and mortising.
Re: back chair rails *LINK*
Jim Matthews
How many chairs do you intend to make?
If more than one, a drying jig for the back slats is appropriate.
That way, all the tenons will come off at nearly the same angle.
As mentioned above, measuring the mortise off the existing tenon
makes sense, to allow for variation between the pieces.
Traditional material choice was determined by trial and error.
Hickory seems to be a happy medium for this.
http://www.woodshopnews.com/news/news-desk/498685-chairmaker-opens-new-woodworking-school
