New WoodChat!
Spice Box- Door panels lined and berried
60 strings and 72 berries and done at last. . Once started it was best to keep at it till done. About the time one gets proficient its over.
The pattern is similar to a classic pattern. However, this box is about half the size of a Period spice Box. I left out half the berries on the interior "petals" to make it less busy. Also half the interior petals don't penetrate the diamond on my pattern. I think the result is not only less busy but attractive.
Note that the worry over compass holes is unwarranted. They just don't show up at normal viewing distance. Anything that doesn't detract from the appearance of a piece at normal viewing distance I don't worry about.
Re: Spice Box- Door panels lined and berried
Gorgeous work
I think your design choices are excellent and I can subscribe to the notion that it isn't essential to fix little blems that are not visible at normal viewing distance. That said, I think I'd putty the compass hole in the middle of that right hand panel as it is quite visible and detracts from the clean diamond motif that you've so successfully accomplished. That would be the test in my mind, such as it is...
an easier fix
The center hole gets larger than most because of swinging the two circles from it. The one on the left which was much larger got filled with water, followed by a wet rag and hot soldering iron. It mostly closes as if by magic.
"What wood is the main board?" You must not be from these parts..... :)
Walnut Every Chester County piece of furniture I have seen is walnut, though in Griffith's PhD thesis on this style it was mentioned that occasionally cherry was used.
A note on wood selection. With the busy lines and berries I thought it best to have the grain as plain as it gets. To that end I found a flat sawed piece of wood where the grain was running almost parallel to the face of the piece.
Well, it didn't look like Jarrah ... :)
I thought it would be Walnut, however it has a look of Mahogany.
Re: an easier fix
Sgian Dubh
Bill, picking up on Ellis's point about the hole in the centre, I think one way to eliminate the need for any disguising work later, an apparently minor task, might be to temporarily stick down a small square of thin plywood (or similar), 1.5 - 3 mm thick, over the centre spot. Work the lines and berries, then lift off the plywood, clean any adhesive off the walnut (double sided tape maybe, or a spot or two of PVA) and polish up. Slainte.
Indeed, a Latta suggestion, but not for me
Latta recommends this approach for those wanting to avoid tell tale traces of how the pattern was made, which I accept has become the current fashion.
Another way to make these patterns is to pattern rout them with a Dremel tool and 1/32" cutter. This approach leaves no compass points.
When I hand scraped my living room floor level I left a few minor chatter marks in the surface as evidence that it was done by hand. Perhaps it is this same philosophy that leads me to revealing to the scrutinizing observer how the door pattern was made.
Re: Indeed, a Latta suggestion, but not for me
Sgian Dubh
Bill, your choice isn't wrong at all. It was just a thought on my part. I do find your leaving of some chatter marks in the floor, er, interesting. It's not the same at all really, but it puts me in mind of the old trick of putting tenon gauge marks in a visible spot (where they really shouldn't be anyway) to kid on to a casual viewer the joint is an M&T when it is, in fact, dowelled, ha, ha. Slainte.
On another note
We have an antique Chester County corner cupboard that is made of apple. My understanding is that it was a relatively common furniture wood in the late 19th century. Sure is gorgeous in its rustic way.
William Duffield
In old ones, the pattern was often designed to hide the compass points under other stringing elements. If the pattern didn't allow this, then they just let them show.
Steve Latta explains that his customers don't appreciate this "charm" of the originals. He has developed a simple tool to avoid leaving any compass point marks. It is a stick long enough to reach to the edge of the panel that can be easily positioned and clamped to the panel. protruding from one end, attached to the bottom in a wide rabbet, is a piece of clear plexiglas. The bottom surface of the plastic has a fine cross hair reticle scribed into it with a sharp knife. To use it, you simply center the location where you want to position the compass in the cross hairs, clamp the tool to the top of the panel, center the compass point on the top surface of the plastic over the cross hairs, and scribe your arc. If you need to scribe a full circle, you will need to reposition the tool once to complete it.
If this is not clear to anyone who needs to build one, I can throw one together, with photos of the process, in about 15 minutes. It'll take me less time than manipulating the photos and uploading them to this forum.
My customers
....are the grand kids. They were fascinated by the creation of these patterns in the door panels. When they have their nose a foot away from their jewelry boxes years hence and see the pin pricks I hope they will remember the process that made the patterns.
Gallery customers may have a different appreciation as they step up from IKEA and may well be more satisfied with a CNC created look.
Re: My customers
William Duffield
Maybe, the only reason for visible compass point pricks is because Plexiglas wasn't available in the 18th Century. :D
Seriously, you couldn't have more important customers than those. They are really privileged to experience the skills that you have invested in their furniture. If you are worried about their long term memories, bring them back into the shop when they get a little more coordinated, and have them do some of the work themselves. Their fist project doesn't need to be a Seymour table. ;) Something as simple as a leaf and berries on a hair clip would suffice.
Nowadays, too many kids' exposure to the crafts is no deeper than scissors and a hot melt glue gun, and their experience of the arts goes no further than interior makeover Reality TV shows. It's no wonder they can't differentiate between quality and IKEA. And then there is this disturbing story:
http://in.reuters.com/article/2015/07/22/usa-ikea-chests-idINL1N1021X220150722
Beyond the tragedy, the anchor brackets are a lot more intrusive than any evidence of real hand craftsmanship would ever be. If the IKEA customers don't understand drywall, there is a good chance that the anchors will be totally ineffective, anyway. Splayed bracket feet and solid hardwood construction are worth every penny.
Re: My customers
Brian Holcombe
Awesome work Bill, I enjoy the subtle hints at handwork. I leave Lot of layout lines and knife marks where they are not easily seen, this is proof enough that it is made by hand.
Bruce McCrory
From a distance the wood choice is deceptively Central American. But neither are readily available to me.
