New WoodChat!
ADVERTISE HERE - FREE TRIAL
Rust
Rust
Rust
Gary B.
How are you gentleman battling rust in your shops?
I've spent most of my life in Upstate NY, and never had much of an issue. I've recently moved near Atlanta, and my garage his HUMID. I went out there and saw some surface rust on my new Lee Valley saws, and promptly lost it...I pulled everything out and soaked them down with WD-40 and a quick wipe...
Not sure If I should try to wax everything? I choose WD-40 because I had it, and my restored Handsaw from a previous thread wasn't rusting with that on it.
Re: Rust
Re: Rust
The solution depends on the tool and environment.
I keep my basement shop under 60% RH and that prevents rust.
We have a big planer in an outside barn. Its bed gets coated with Boshield. I have had water condense on it and it didn't rust. But this stuff is sticky and I suppose unsuitable for a hand saw. You may have to store these tools inside.
Re: Rust
Re: Rust
Doug Trembath
Any port in a storm initially, when you discover something like that, but paste wax works in my shop. I currently have water come in at the base of two walls during the rainy season. Not a lot, but enough to keep it much higher humidity. Something I just have to live with until I hit the lottery or suddenly become famous. Probably the same odds of either happening, so...
Treewax, and Johnson's paste wax have both been used in the shop successfully. Renaissance wax would be better, I think, but you can pick this stuff up at Lowe's, etc.
Doug Trembath
Re: Rust
Re: Rust
Jim Matthews
Similar problems arose when relocating from the Adirondacks to South Coastal Massachusetts.
I've slowly trading off cast iron tools, where wooden body versions are available.
Chisels, plane blades, saws and cast iron plane bodies get a swipe of Canola oil after each use.
I'm finding that saw blade covers must be plastic in my shop.
Wooden ones act as a "moisture magnet" and rust the tooth line.
The emitters and treated bags from Lee Valley are effective, for things stored in drawers.
My take is this; most any oil that doesn't evaporate will work to restrain rust.
Storing things in wooden drawers, boxes and cabinets will slow the deposition of moisture in a damp shop.
Re: Rust
Re: Rust
Howard Pollack
I have the same problem- I bought a house within viewing range of the ocean, all the tools in the "barn" are developing rust. I've heard that a closed box with an electric light to keep it worm is helpful. This is a big problem for me and I need a good solution. Will buy a dehumidifier soon.
-Howard
Re: Rust
Rust Buster-- Sheep!
Bruce McCrory
My Veritas LAS turned into Ronald McDonald over one summer and fall.
Wool fat. Lanolin. Great for chapped hands, too.
I tracked down a spray can version, "Fluid Film", sold at O'reilly automotive stores and spray it into deep crevasses. Each tool wears the cotton painter's rag--think dry-ish dust rag--used to wipe it down. No more rust. I wipe down after use mostly to remove sweaty paw prints which do etch metal surfaces through anything but paint. The oil is persistent on the critical cutting surfaces, where I concentrate coverage. No gummy buildup.
Lanolin is old school but works in some pretty adverse conditions.
Re: Rust
Re: Rust
William Duffield
WD-40 is temporary. It evaporates after a few days. But it's just what you need, immediately, if something gets rained on or dropped into a puddle, or if you know you are going to use the tool again in a day or two. If you use the T9 Boeshield, you can spray it on and wipe it off if you are going to use the tool soon. For long term protection, as noted in another post, you spray it on and leave it in place, and it is gummy. To get the gum off, I spray it with WD-40 and wipe it off, and then try to remember to reapply the Boshield before i put it away.
When I uncrate a new machine, WD-40 is the best thing I've found for dissolving the cosmolene, or whatever that yellow grease is that they ship them in from China.
Re: Rust
Re: Rust
Curt Putnam
CorrosionX HD in my shop. Truly synthetic motor oil works well too. I learned about CorrosionX when I was salt water fishing. It kept my gear spotless while it endured 7 days & nights of salt water and salt water spray on a fishing trip. It kept treated tools rust free in an unairconditioned garage while the untreated tools had rust blooms all over. I just spray a little on a micro fiber rag for hand tools and wipe them down after use. I keep the rag in a sealed jar. Same spray can has been with me more than 15 years so a little goes a long way.
JMO & YMWV
