Re: saw plate cleaning advice
Peter Evans
Eric, the scraper will not take off the etch. Sandpaper will. So in the area of the etch, use a higher grit with a hard block (a bit of wood with a sheet of cardboard glued to the face works well - also glue the sandpaper to the cardboard to ensure it stays flat and does not move around) to determine whether there is an etch. If not just go for it with paper starting at 80 or above, depending on condition of plate (I use WD40 as a lubricant). If there is an etch quarantine the etch area (cover with blue tape) and clean the rest of the plate to about 400 grit.
Then remove the blue tape and carefully sand the etch area, starting with 400 until as shiny as you can get it. When as far as you can go, use a Klingspor Fine sanding block over the entire plate to remove sanding scratches, this should not noticably impact the etch, but worthwhile to be careful in that area.
Then use scrunched up alum foil with Autosol (bettter than Brasso in my opinion) to polish the plate. This does not abrade any metal is my understanding, but sets up a chemical reaction to polish the steel. Wipe off with a paper towel, then use a solvent to completely clean the plate (no solvent on etch area). Then repeat this step just with foil, and your plate will be about as shiny as it is ever going to be. The pits will still be there. You will note that a black deposit from the foil reaction remains in the etch, don't know how long this lasts.
The steel is now subject to rusting again, so a wipe on of microcrystaline wax designed for metal will protect the plate. I have also found that a light oil (3in1) wiped onto a heated saw plate (hair fryer, placed in front of heater, or out in sun) keeps rust away, wipe off extra oil while still warm.
