New WoodChat!
Knife edge taper
Knife edge taper
Steven Antonucci
Knife edge taper
steven antonucci
I have a bunch of 1/4" thick x 1 5/8" wide "slats" that I need to cut a knife edge on along the length. They vary from 10"-22" long, and I am afraid that the tablesaw will be dangerous as well as destructive because they are so thin.
Anyone have any thoughts about how to build a shooting board to thin one edge with a block plane or similar?
Steve
Re: Knife edge taper
start over
Cut the taper on the edge of a 1 5/8 piece of lumber then slice it off 1/4" thick with the saw. Not hand tool but I would do the taper on a jointer and slice on a table saw. Trivial. I make most of my moldings this way- edge a wide piece and slice it off.
Couple things
Wiley Horne--So. Calif.
Hi all,
1. By eye. I think I'd mark the slat edge (centerline) and both sides, and just plane till I was shaving the pencil.
2. For an angle guide, clamp a longish plane down sideways on the bench, so the iron is vertical. Then rip a bevel (45 degrees or whatever angle you want) onto the edge of a length of 2x4. That's your edge guide. Joint the knife edge of the bevelled 2x4 back a little until it is dead straight and free of splinters. Butt that jointed edge up against the plane sole, so that the bevel slants down into the blade. Run the marked slats along the bevel and against the plane blade--stop when you're shaving the pencil mark on the centerline of the slat edge.
Wiley
Re: Couple things
Patrick Gibbons
I'd do it by eye also. Mark with a pencil and have at it with a smooth, jack or block. Looks better (because of the hand made look) and is a lot safer than power tools.*
*All opinions given are the writer's only and may not reflect the views of anyone else, living or dead.
Steven Antonucci
By hand is the current mode
steven antonucci
I have some ideas for a sled, but short term is to continue with a spoke shave...
Thanks for trying.
Steve
William Duffield
I've made knives using a jig that holds them mostly vertically, at a small angle, in my radial arm saw. They are held in place with a toggle clamp, one side is cut, the stock is moved to the other side of the jig, the jig is moved along the fence a small amount, and the other side of the blade is cut. The toggle clamp engages the bottom edge of the stock, which is left uncut. The jig is clamped to the fence, with a pair of stop blocks. However, for blades more than about a foot long, you would need to make four passes, and reverse the stock, due to the limits of the RAS travel. If you are interested it trying to build and use one of these, I can get you some photos that would make it clearer. Also, the jig wouldn't work with most chop saws, because the depth of cut needs to be limited.
I've also done them with a block plane, between bench dogs, and judged the bevels by eye, but that would be much too slow for more than a very few.
Another possibility is to build a sled that could be run through a wide belt sander. You would need two passes per knife, but could make the sled to hold several at a time. I would not try this method with a planer, because it would probably shatter the edge on the second pass.
clarification.....
"1/4" thick x 1 5/8" wide "slats" We are talking slats here not knives?
"Anyone have any thoughts about how to build a shooting board to thin one edge " We are tapering one edge, not both?
In either case it will be trivial, and no less safe than any ripping operation, to saw these from the edge of a wide board using a table saw.
Steven Antonucci
Update
Steven Antonucci
Well, I figured out a way to do it.
The slats had two holes in either end, so I made a quick push block with a peg to fit the hole. After three or so practices, I turned the last 40 over to my 17 year old son...who finished without issue.
The slats were beveled to a knife edge along one length at 15 degrees.
S
