New WoodChat!
ADVERTISE HERE - FREE TRIAL
Sawing a Tenon
Sawing a Tenon
Sawing a Tenon
Most of us have cut a good many mortice and tenon joints over the years. It occurred to me today to ask a question about something we likely take for granted: Do you saw the cheek first, or the shoulder, and how far to the intersection do you go?
For myself I saw the cheeks (as close to the markings as possible) ...
.. and stop a smidgeon short of the shoulder line.
Having created a knife fence on the shoulder line, I saw the shoulder close to but a smidgeon short of the cheek line ...
Then it is a case of back-and-forth to sever the bit between ..
It will eventually pop off nice and clean ..
The vanity cheek may now be sawn. This is 1/8" (3mm) ...
.. or the haunch created. The haunches are for the upper side of the panels, with the blind M&T at the lower end (as they do not go all the way to the bottom) ..
I am now ready to measure and fit to mortices, and then complete the mitres for the coves, and fine tune the shoulders ...
Ready for the weekend ...
Re: Sawing a Tenon
New term to me
What's a vanity cheek, besides the cheeks on a supermodel's face?
Re: Sawing a Tenon
I chisel the shoulders
It is the only way I can reliably get them to come up tightly. The extra time it takes to chisel to the shoulder line is compensated by making the other cuts with a band saw.
Re: Sawing a Tenon
Re: I chisel the shoulders
.... but you must still saw the shoulders (before you use a chisel on them, which is just a fine tuning method). So which comes first, the cheeks or the shoulders, and why?
Re: Sawing a Tenon
Darrell in Oakville
Re: Sawing a Tenon
Darrell in Oakville
Derek asks one of those no-right-answer-no-wrong-answer questions:
I saw the shoulders first, and I go right to the line. I usually don't saw the cheeks, I split them off. If I have to saw them due to bad grain, I will. I would use very straight grained bland stock for the rails and stiles, and save the pretty wood for the panels. And the bland stuff usually splits very nicely.
Darrell
Re: Sawing a Tenon
Cheeks then shoulders
I don't know why. Maybe because it is harder and I want to get the harder part over with first.
Re: Sawing a Tenon
Re: Sawing a Tenon
William Duffield
I saw shoulders first. If I were to oversaw a cheek, it would show. If I oversaw a shoulder, it doesn't show, but I still need to be careful, because it weakens the joint. I stop sawing the cheek when the waste falls away. It's a lot more precise than watching it closely and guessing when to stop.
If I'm doing it on the table saw, I saw the cheeks first. If I were to saw the shoulders first, the end of the tenon has a lot less support on the saw table, and could drop into the slot in the insert. Also, I like to have my hands farther from the waste block when the saw blade kicks it out.
If I'm using a "Festool drone,"* I don't saw the tenons, and a bench plane on the shooting board takes care of cleaning up the shoulder :D
* http://benchcrafted.blogspot.com/2015/05/handworks-2015-video.html (About 7:00 minutes in)
Re: Sawing a Tenon
Re: Sawing a Tenon
David Charlesworth
Cheeks first for me.
I like to use my large bandsaw and would have waste trapped between blade and fence if shoulders were done first.
Best wishes,
David
