New WoodChat!
purchasing calculation problem
Jerry Gibbs
I have several times calculated the optimum lengths of hardwood needed for a project. Then have to drive 35-70 miles to purchase. At the dealer, they will not have the lengths I want, so I have to do a fast re-calculation, which is not my forte. I don't know if there is an answer. I don't mind buying long lengths of fir, for example, since the cutting will be more efficient. This doesn't work with most hardwoods. Do I just buy lots, put in on the credit card and have left overs?
Re: purchasing calculation problem
widths are also a problem
Jerry Gibbs
probably more than lengths
Paul M
Chalk and a measuring tape are what I use. If you know that you need 20 pieces at length A and 10 pieces at length B, then grab the boards and mark with chalk every length of A+2" and B+2" so that there's a bit of waste available on each piece. When you have reached your needs, stop buying (that's the part I have the most problem with). This requires no math, just tallying.
No such thing as hardwood left overs
Someone gave me a pile of short walnut pieces and in the course of a few years it has all be used instead of cutting up longer pieces to yield short pieces for projects.
If you have the room and cash consider a hardwood purchase as an investment that will appreciate with time. It is astonishing when I look at our old purchase records what we were paying for hardwood lumber some years ago. And the quality hasn't gotten any better either.
There is much in favor of deciding on a wood you like and buying enough of it to be able to buy it from some wholesale place that caters to cabinet shops and other professional customers. And then you might have 200 or 500 bdft to pick through to find the ideal sizes and grain for a project. Waste becomes near zero in this case and the projects become spectacular when the grain is ideal for the project.
Re: No such thing as hardwood left overs
TomD
I agree with Bill, back when Oliver lumber was still in TO, they had a minimum, but they would bend a little to about 300-500, back when 2 a bft was common. That sets one up.
I am very good at head math, but I can, t do what you are asking about. It is actually pretty complicated when one considers there are normally pieces at home that enter the equasion, few places want to spend the time to let you go over every piece, and the light may not reveal everything. And so on. So getting more. Buying wholesale, limiting the species you handle, and maybe coming up with a thing you make out of scraps, are about the best you can do
david weaver
If I can find it deal price, I will buy about 30%-40% extra if ideal widths and lengths aren't available. If it's premium price, I expect to be able to pick through it and I will buy one extra board for margin of mismeasurement, etc, but that's it.
if the pieces off offcuts are tiny, then I just throw them out. I don't have a practical way to burn them, or I'd do that. I guess they'll end up as methane in a landfill. If they are substantial, but longer (like 2x2 inches and 6 or 7 feet long), I save that stuff either to cut blocks or to use in the garden.
