New WoodChat!
Hand Tool Chat - Tonight, April 7, 9:30 p.m. EDT
William Duffield
If items left open from last night's general discussion are any indication, I think we're going to need some steam bending expertise tonight. I have plenty of book-larnin' on the subject, but very little practical experience. If you have pre-ordered Peter Galbert's "Chairmaker's Notebook" from Lost Art Press, it should be in your hands presently, with pertinent information on this subject.
Re: Hand Tool Chat - Tonight, April 7, 9:30 p.m. EDT
TomD
I've done a few projects, obviously lots of guitars, but bamboo bike fenders, tool handles, and so forth. If you get the project hot enough it is simple. problems are mostly to do with failure to heat. Steam is the main way to get the heat into the wood that needs to be bent but can't be dry heated or is too thick. Water in itself is bad because it lowers the tensile strength of the fibers most likely to yield. That is where strapping helps, or part of the story. I once bent a very tight radius in 1/8" ebony by backing it with masking tape, worked great. It doesn't ahve to be a steel strap. With ebony you can't read the grain. In the years I have been making guitars, they have moved to silicon blankets to get the serious heat in there. There are ebay cheapos now available at a reasonable price with free delivery.
William Duffield
I guess if you can bend ebony, we should be able to bend walnut. I'm sure there will be questions tonight, especially since I don't think the guy who is in immediate need of the info visits this forum nearly as often as he visits the Turning forum. Thank you. You're always very helpful. I'll provide a link for the chat to the info you've provided. When doing Federal inlay work, we often bend the stringing between an automotive feeler gauge and a shellac burn-in pen. Of course, that provides dry heat as well.
