Re: Cheek Floats
david weaver
I've made all of the finishing cuts in those spots with a 1/2 inch paring chisel across the grain. I couldn't get satisfaction with the floats, and they tend to scuff up corners unless you're really careful, but I think your idea sounds like a good one.
the first few planes I made, I finished all of the inside surfaces with floats, but now only the endgrain surfaces. I tried the bed float and the cheek float, but it always feels awkward. The cheek float gets everywhere, but if you go fast, you'll end up with uneven surfaces and lines. Something between the two in size where there was an extremely slight radius on the tooth edges would be nice because it wouldn't leave witness lines everywhere.
I have lower visual standards to adhere to than you do, but I think your idea of a finer float is a good one, and the corners will definitely have to be relieved to make the cut. I'm going to continue just chisels and scrapers on the cheeks, I'm getting better results leaving the floats out of crossgrain cut.
on the subject of hardness, my edge float is only hardened on the last two inches, and those teeth are too hard to file, I've left them that way. after a couple of dozen planes, they are a little bit dull and the rest of the teeth obviously are, too. I like the way that plane works for opening things up, it cuts but it doesn't grab - you can keep it in motion the whole time and not fight it. Opposite of the bed float, which works miles better (faster) on a slight drawing cut if it's totally sharp.
