New WoodChat!
Question on miter saw
CJ in MPLS
Since I have about six unfinished projects underway I thought I'd start another one yesterday. A few weeks ago I attended a class in hand cutting joints at Mike Siemsen's schools just north of Minneapolis and he had a miterbox (hand) set up for cutting wood for sample joints. Recalling that I also had one of those in my attic, as well as a saw purchased for use therewith, I dug the two of them out and spent the afternoon cleaning them up a bit.
The saw, Simonds with I think very little actual use, was a bit gunky and needed sharpening. It cuts better now, but will only cut as it should once I become a bit better at sharpening. I will also need to adjust the settings on the box itself as it is a tiny bit out of square. That will wait a bit however.
Re: Question on miter saw
So what was your question?
If the question was, "do I have a good miter saw?", the answer is, "yes."
Re: So what was your question?
david weaver
Nice setup, as Bill says, but worst saw in the world to sharpen. When you're right in the middle of it, it seems like it has a million teeth.
The question was lost
CJ in MPLS
in trying to get photos from my phone to the internet. No drive by's intended.
The question was going to be along the lines of what tolerances do you folks tend to use when assessing the results from a miterbox? I have some work to do on both the box and the saw. No mechanical item will stay perfectly square over its entire life and this needs a bit of adjustment (very small adjustment, but I can see a bit of light between the wood and the square). I also need to look at the saw again as it seems to have angled into the wood and the straightened out on its way down, leaving a bit of a concave face. Not much, but not perfect either.
Just trying top benchmark the adjustment process I'm looking at is all.
CJ
CJ in MPLS
This will answer, almost entirely, my missing question.
Thanks,
CJ
Re: The question was lost
david weaver
It should do small work (small mouldings, etc), at least those of the small that are large enough to tolerate a saw that heavy - well enough to just about be done with them.
Large miters, etc, you might have to do a little bit of fitting. Cut quality should be almost as good as a power miter saw.
I can't remember who said it, but I remember when the rage came to buy these as a result of the PWW blog post or article about them, the phrase "construction tool" came up when describing accuracy.
I've got a millers falls 74C, and it's a very accurate device, but not any more so than an old dewalt chop saw that I have, and in general, it's cumbersome to use and you can get close to the same accuracy on 90 degree cuts with decent sawing skills.
picture from phone
Jerry Gibbs
I have an iPhone. I crop the picture on the phone and then email it to myself using the small resolution. I then select the pic from downloads or wherever it is on my computer and attach it to my woodcentral post.
Re: picture from phone
CJ in MPLS
No problems with the process. I just have trouble keeping more than one thing going at a time.
Kevin French
I love my mitre boxes and saws
[URL=http://s56.photobucket.com/user/sweeper54/media/shop/Mitresaws.jpg.html][/URL]
