Re: 3-D Printing
TomD
Yeah this is going to be way more complicated than it is worth. But it can be fun. I started CAD back 20+ years ago, and there is a disadvantage to that in that the modern "maker" approaches have seriously deskilled the process, which is what one want if one wants to get results. Maybe you have a local maker space that would have the tools and info you need to get a quick start.
There is a website that starts as shapes that you can then modify to do your thing. It is called Blender. Since I learned old fashioned cad, I can't really say how easy you will find it as I don't use it. But the idea is certainly to make it easy.
Can you turn regular pictures into CAD? There are file transfer softwares, like I use Inkscape, which is free and I just use it to convert PDFs. If you look up jpg to dxf transfer utilities you can find stuff like that for any format. Already existing programs you use like photoshop, or Corel Draw can allow you to save one format into another. But how useful it will be depends on how convertible the file is. Something like a very clean outline is probably easiest. What I normally do is import pictures then draw over them to get an original CAD file I can use. CAD is good because it can be most easily converted into machine instructions, and it can be easily modified for sizing and so forth.
The way one would normally make a sideplate would be in 2.5D You draw the profile, and then you simply add those 3 dimensional aspects to the G-codes that will allow a machine like a router to cut it out, so the machine has to know how deep to cut each pass. But basically it is just making an outline. In printing the machine needs to know the rate at which to build stuff up. But you can get into actual 3D if you need to add a real third dimension to the part. There are softwares that do specific things like create the 3D sculpturing that is required to a person's face, or make a wing. These are simplified single purpose interfaces that do this stuff efficiently without your having to master a lot of steps.
You can outsource the work to companies that print stuff at a reasonable cost. Shapeways is one of these, but there are others. They can do a variety of metals.
