New WoodChat!
Beech by the bunch
Beech by the bunch
Beech by the bunch
Beech like the tree shown are common. Beech is considered a worthless tree and they are unfortunately left when a woods is logged to occupy space where somethig useful might otherwise grow. Any land owner with sense would be delighted to be rid of them. A good deal would be to saw out the plane body material and cut the rest up for firewood for the land owner.
This tree will yield about 800 hundred bdft of lumber but an unknown amount of lumber useful for planes- maybe 100-200 bdft. Is is a straightforward task to cut the tree down, saw it into blocks and in turn saw the blocks into billets that will be quartered. All this is common practice among the turners. For the price of a chain saw and way less time than it takes to make a plane body anyone living in the east has no reason to be without wood for their plane making needs.
Re: Beech by the bunch
david weaver
I wish I had a beech tree around here, because me, my saw, my maul and my gallon of bleach would be there ready to split billets out of any tree that had good vertical grain.
I pass a lot of wood on the way to work here, a half mile walk to catch the bus. Literally no sizable beech trees. To the southwest of here in ohio, they are out there in great quantity (and used for firewood most of the time as far as I know, except you've mentioned that it's popular for railroad ties right now).
200 miles to the east of here (gettysburg, pa), we cut and split and burned 12 cords a year when I was a kid, and red oak was far and away the most common thing we burned, cherry second, and probably locust third. The only other tree I can remember seeing a lot of that was hardwood was hickory. Two years ago, I walked my parents' property (15 wooded acres) and there were no sizable cherry or beech trees, anywhere. I probably am remembering there being more cherry than there was just because of the wonderful smell when you split it, as opposed to the smell of feet that comes out of red oak.
david weaver
By the way, is that your double bit axe? Looks like a cruiser. Who made the head?
John Sayles
David, for those of us who don't know, can you explain the use of the bleach?
Thanks in advance.
Re: Fungus
david weaver
Wet beech gets a black or dark gray fungus or mold on it very quickly. A lot of my 5/4 and 4/4 beech has just a little fungus or mold evidence on it (that must've occurred right after sawing), but when you plane the rough off, there is still some evidence below that of discoloration and you have to remove more yet to get through all of it.
I don't know for sure that the discoloration is due to the mold, but I would suspect it is.
None of the "expensive" beech that I got from horizon has much or any of that on it.
I'm assuming that it air dried and the surface wasn't wet for long, but I'd bleach it just in case to kill anything on the surface while the surface still had high moisture.
The ax
I was with my father when he bought the ax in Long Lake NY for trail clearing (he was forest ranger in Adirondaks) in the 1950's. I wound up with it rescued from the barn rusting and rehandled it wth a nice handle. Yes cruiser. Don't know the brand but it is a dandy ax, perfectly balanced. I can and do limb with it one handed with about the same effort as two handed.
Re: It's all talk...
TomD
till someone does it. Which further applies to turning these babies into more planes...
The long one is 26+ 4x4. The others are wedges for various molding lanes, though they are big enough for smoothing planes. I have enouch splits for several sets of H&Rs, and quite a lot of boards cut for bench planes, as well as some stuff for benches.
You will note there is no mold no check, nothing. Very easy wood to handle as long as you get it through the first few days.
Coincidentally a guy who wants me to cut up some 24" maple and cherry, tells me we have some kind of blight in Ontario and the beeches will all be gone soon enough, so it would make a lot of sense to get them down and into a form you can use because it may not be so easy later.
Re: Handles
TomD
One thing that is not always available are handles. I like mine over an inch wide, but not all that much. I was sure to cut some wood just for that because 4/4 is too small for me, and I normally don't do much under 6/4, and then one looks at a nice board of that and doesn't want to waste it. So I make sure to cut some specially for the handles.
Re: Handles are a nice side product..
david weaver
... of having scrap left over from full sized billets.
I haven't had to remove more than an inch from any billet yet, but I have had checking in the ends of several planes and one of them did develop into something visible more than an inch in.
I agree with your comment, it's not fun for me to pay $800 for 60 bf of beech from horizon, but coming up with stock that they have as it's delivered to me (dry and ready to use) isn't quite so trivial if you've got no way to haul logs, no beech trees to cut and nowhere to dry them (that's not entirely true, I could dry them).
TomD
There are a lot of ways to really hurt yourself around trees. Last year a couple down the beech from us his wife was killed when an Oak just fell on her while she was reading... Last summer we had the wind storm and all the standing timber to deal with. This cherry, I am after, it sounds like it is hung up. That can get real exciting. I liked that the beech was on a managed lot, and the guy insisted on knocking it down for us. I haven't had a problem with a big tree that was standing, but wouldn't it just happen on some guy's lot.
When I did the beech a while back I was in quite a bit better shape than I am now, the saw is a huge stress to push through, and moving all the wood, though I pretty much have it down to a science.
Bill's point that for planes you can just knock a nice tree over and split out the parts is true, particularly with a large splitter. I have had more trouble that I would like to admit splitting stuff. Really fabulous wood better than you can buy can have tiny twist that makes pieces in longer lengths very difficult to split. But they are relatively easy to cut with a chainsaw, or a bandsaw. You can split them in half and then do the rest with tools.
So while 13 bucks a foot is rich, it is well worth it if you can just get on with it. The thing that drove me to saw it up was the fact that I couldn't find it at any price. And on that day it was a fun job also.
