New WoodChat!
taking the bluing off
McKay
A number of years ago we built a brass backed carcass saw in a summer class for woodshop teachers. We used the blued spring steel for a saw plate. The saw cuts straight, but I would like to get rid of the blue so that I can see the cut being reflected in the plate as I am cutting. Does anyone know how to remove this bluing? Thanks in advance.
Re: taking the bluing off
Lots of options....
John in NM
Some probably more safe for the brass back than others.
With any, you will have to remove the handle.
Bluing is just an iron oxide, so you can use a weak acid to dissolve it, either oxalic or citric are often used.
Another option is 10% solution of molasses in water. No clue how that one works, but Bill T. could probably tell you. It's pretty slow as I remember, but it's about the safest method.
There are also chelating rust removers available at auto parts suppliers and Harbor Freight that remove oxides without etching the steel below.
With any of these, I would follow up with a good rinse with either alcohol or acetone around the brass back to hopefully pull any water out of the joint between it and the steel.
  Figured you'd know!
And you cat can clean up for you
Dick Coers
Love the smell of molasses. I remember one event when I was a kid. My Dad somehow got a 55 gallon barrel of molasses that was tainted or something wrong that it was not food quality any more. We spread some lines in the cattle trough, then covered it with oats. Ever seen a cow smile?
Anybody that bakes knows
Any recipe with Molasses will have sodium bicarbonate added to neutralize some of the acidity and make CO2, Grandmothers Molasses cookies for example.
Re: sheep too
Ron Pemberton
I am a veterinarian and cows smiling and sheep's reaction made me laugh. Good ones.
Dominic Greco in Bucks County PA
I use a 10% solution of citric acid and hot water. Wipe down the saw plate with mineral spirits to get rid of traces of oil before you dunk it.
And by the way, the web site is www.tgiag.com
