New WoodChat!
How is a draw pin(oblique pin) actually used
Situation- frame for a panel door. Two pins per M&T joint. We don't have the holes bored yet. What are the steps for locating and making holes, then drawing and pinning.
When my chair friend pins a joint he pulls it up with a clamp, locates the hole on the tenon from the already made hole in the mortise, takes joint apart, drills off-set hole in tenon, reinstalls the tenon and pins it.
Using the draw pin requires the properly off-set holes in the mortise and tenon to be there, and, one can't pin the hole with the draw pin in it. I can't get past the chicken and egg situation. To test or pull up the joint we need the properly off-set holes. To locate the tenon holes we need the joint pulled up. To pin we need the draw pin removed. I'm missing something. It looks to be satisfying to use, but how?
Re: How is a draw pin(oblique pin) actually used
Missing Something
Have used draw pins a number of times.
1. Drill the mortice (1/4" hole) thru the face and half-way through the other side.
2. Insert and clamp the tenon.
3. Use a brad-point drill to mark the center of the pin hole on the tenon
4. Remove the tenon and drill the hole (1/4") off-set to the outside by a shade
5. At assembly, glue and reclamp the joint, then drive in the tapered draw-pin.
6. Trim and sand the pin flush.
There's only one pin in use, the draw pin which is wood and is used to make the joint, not some tool used for the effect. You lost me when you speak about the "pin" and the "draw pin" as different items.
PS: When doing breadboard ends, I use three pins. The center pin being straight and glued, but the outside pins being draw-bored to keep the end piece tight at the joint line yet allowing the panel to move in and out seasonally.
Missing Something- a better question description
I get that part. It is how my chair making friend does it. It is the use of the thingy that Joel described that I don't get- the clamp-free approach.
Re:  Missing Something- a better question descript
wilbur
The drawbore pin would be used between steps 4 and 5 in Mark’s description. The main purpose of the drawbore pin is to pull the joint tight so you can see how the joint looks before you drive in the wooden pins.
Whether this needs to be done for all joints is another matter. I haven’t found the need for it so far, and that includes drawbored mortise and tenon joints for furniture-size projects and the joints that hold together the legs and stretchers for my workbench.
Re:  No-Clamps
I've done it that way as well. Assemble the M&T to mark the tenon. Drill the second hole. Then glue, assemble, and drive in the pin which will pull the joint tight even without the clamp. Did several tables that way because I had trouble properly clamping a 6' assembly of the breadboarded tops. I prefer to use the clamp because I think it takes some of the stress off the sides of the holes.
Missing simething
Warren in Lancaster, PA
What you are missing, Bill, is a lot of extra steps.
Indeed that seemed to be the case
But since I have no direct experience using this joint or the drawing tool, having only watched the chair person pin in what seemed a more straightforward way, I thought I must be missing something.
I have noted that the responders mention clamps. Yet my query was how to use the $100 drawing pin that is supposed to avoid clamps. While the cleverness of its geometry for the task is interesting, I remain befuddled how it is practically helpful.
But....
In step 2 a clamp was used. Why would I own a $100 tool to do step 4.5 when I used a clamp in step 2. to accomplish the same result?
Clueless as Well
never knew there was such a tool.
Re: Indeed that seemed to be the case
Jeff Heath
The only time I have used a drawbore pin vs. a clamp was when pinning a M&T joint on a table frame assembly where the length of the table exceeded the length of clamps I had laying around, without having to run to the hardware store to buy 3/4" pipe unions to lengthen pipe clamps (which I personally don't like to use anyway).
I had two vertically situated pins, and used my drawboring tool, which is actually a Starrett pin punch serving double duty, to pull the joint tight on the bottom while I marked the top hole. I reversed it to mark the bottom hole.....drill holes offset, glue and pound in peg.
If that's not historically correct, then my explanation is worthless. It worked flawlessly for me, though, without a clamp that was 10 feet long.
That's all I've got...
Re: But....
wilbur
Well, I don’t use a clamp for step 2. I just fit the joint together and mark the tenon through the hole.
Larry Barrett
I think the oblique drawbore pin(s) would be used after the offset hole has been bored in the tenon to ensure that the rail shoulders actually will pull up tight against the post once the actual wooden pin is driven into the drawbored joint. A careful examination of allsides of the rail shoulder might obviate the need to pull the joint together with the oblique pin.
Example
6' coffee table in cherry and walnut
Ordinary taper pins ...
Larry Barrett
or even the actual wooden pins, carefully inserted in all the joints, are very useful to ensure the whole assembly goes together, as others have pointed out. No need for lots of clamps this way. Just make sure you can pull the wooded pins back out before you do this.
You must have some tricks.......
....for getting all those shoulders to come together tightly. I can imagine "fixing" one and throwing out 3 others.
Bob Hackett
As I mentioned in my comment about metalworking a fitting pin is used not so much as a tool that allows the marking and drilling of the holes, those are done during layout of the joint. What a fitting/alignment pin does is either pull the two pieces into alignment so you can get one of the bolts or rivets started or pull it into close proximity so you can see where you need to trim in order for the parts to come into alignment.
As Joel stated, these tools really shine on larger work, from doors on up in scale. Try clamping a large curved white oak forefoot to an even larger keelson on a wooden boat to see where they earn their money.
The short story is that if you have clamps and enjoy working with them then you don`t need a drawbore pin. If you do work that involves non-straight sections, odd angles, or other hard to clamp areas then you now have another option to look at.
Just another point to consider in relationship to draw boring. I have yet to hear anyone mention a froe or a pin plate(used to size the wood pins) in their discussions on proper draw boring tools. For the pins to deflect as they should they should be made from riven stock and driven thru a steel plate for consistent sizing. Wonder why we never hear about these tools being included in any cabinet maker`s tool boxes if they used pins? I suspect they would be a much used part of both a bodger`s kit as well as a chairmaker`s.
Different disciplines use different tools. As a person progressed from timber framing into making things like sashes and doors I suspect they would bring the techniques that were successful along with them as well as the appropriately scaled tools. Likewise, an accomplished trim carpenter might one day decide he`d rather settle into working in an established cabinet maker`s shop rather than traveling on to the next unfinished house (especially in winter) or working in a mill making the same thing day after day. His knowledge of how to make and fit multiples of something quickly might be what gets him through the door. Quick, accurate, in position adjustment coupled with a quick twist to bring it home is what draw bore pins are all about.
Everything good? Quick twist in the opposite direction releases the metal pin and the wood pin is driven home. No fumbling around with clamps, no false starts, no drilling out stuck or broken pins. the feedback you get from using these tools makes all the difference. Like anything else you have to practice and pay attention to what that practice is telling you.
Doug in OR
Is the glue even necessary - I did my first set of drawbore M&T last night for my sawbench. The bench is made of Borg Doug fir and I made the pins out of white oak - rived and roughed to cylinders with a chisel. The first mark I made I clamped the joint to mark it and on the second I did not bother. I offset by 1/32 (I measured the first and eyeballed the second). No glue was used on either the tenon or pin and they went together beautifully. The pins were slightly tapered, I believe Warren recommended that.
Dowel Plate
Dowel plate is another tool that is hard to find in inventories. The pins for mortise and tenon work are not dowels at all. They are tapered. Putting stock through a dowel plate is too time consuming. For 1/4 inch holes, I make a dozen tapered pins in 8 minutes.
I get to work on a barn occasionally. I have done both joint making and raising. For a raising we usually have forty or fifty guys helping, so there is a lot of experience around. Most of the guys are descendants of the original Lancaster County settlers over 300 years ago and have been continuously engaged in farming since that time. I have never seen a hook pin in use in this neighborhood. They just aren't needed. One time I helped disassemble and move a heavy timber cider mill building in a nearby county. When a peg broke, tool dealer Bill Phillips whipped out a hook pin to get it out of the hole. That is the only one I ever saw.
Larry Barrett
This is a photo of a trunnel, used in old houses or barns for M/T joints. It came from my Grandmother's house where she lived when she was a little girl (around 1880) - yellow pine. With the tapered tip (oblique cone) it might look like the drawbore pin that Joel is talking about, although of course this is wood, not iron.
Transfer punch
Alex Grigoriev
Get a set of transfer punches (Lee Valley SKU 24K05.040). They are very useful sometimes.
Re: You must have some tricks.......
Larry Barrett
Most important trick is to not look too closely. The important shoulders on the face are defined with a knife line, a groove for the saw is then defined with shallow chisel cuts to the knife line. The shoulder is then slightly undercut with a saw. The teeth of the saw do not touch the surface. Unseen shoulders are sawn to ensure they will not interfere with the face shoulder. This is 17th C joinery, a la Follansbee and Alexander.
Trunnels
Bob Hackett
The word is actually derived from "tree nails".
This type of connection in what held all the thick planking onto the white oak frames of the wooden schooners built up here in New England. The last ones we dealt with were made from riven black locust (chosen for it`s resistance to rot and marine borers) and over a foot long in most cases. Picture 4" thick old growth SYP planks that averaged 8" across and no less than 10 feet in length fresh out of a steam box and working off staging. Not much time for fumbling with clamps here.
The smaller pins used to fix trim work were driven thru the sizing plate by swinging a good sized wood mallet at about one second each after the riven blanks had been pointed on a power driven spoke pointer which also took less than a second (I salvaged one on these shop made pointers, they were rather crude and used sections of old planer blades for the cutting edges).
The locust trunnels were fed thru a machine that milled them to size, one man pushing ,one at the other end pulling once he could grab the newly sized stock. This was work usually handled by laborers or apprentice joiners. Once you had proven that you could focus your attention and move thru the work while producing both quality and volume you might be invited to move on up to join the planking crew or tend the steam boxes.
Most of the shops still building or repairing wooden boats here in Maine still use the flat belt driven machinery and shop made tooling that was used over a century ago. It`s like going back in time or being an employee in a working museum working in the smaller boatyards up here.
Here`s a suggestion
Bob Hackett
Go down to the local flea market or second hand shop and buy a couple of tapered punches.( I can get all I`ll ever need for $1 each without going to yard sales)
Grind them to conform with the pics that have been provided then polish the ground surfaces.
Don`t have access to a grinder? Throw them in a fire and then let them cool slowly while covered in the ashes and file then sand the now soft steel.
Learning by doing has always been more successful in turning on the light over my head than any other process I know.
I guarantee you will not regret spending less than $5 to actually learn how these type of tools work. If you don`t find them useful for alignment and draw bore purposes then grind the tips back to flat and use them as punches. You`ll still get your money out of `em.
