New WoodChat!
UPS Brings a Surprise
david weaver
I don't normally post "I just got this" kind of threads, because I get so much stuff and then use it and then run it through (as in dump it), but today I got something in the mail that is really a once in a lifetime kind of thing.
I'm not going to name the person who gave me the opportunity to have these two chisels (that is up to them), but I can't put in words how much I appreciate it.
I got these off of the UPS truck tonight just before 8 pm, and immediately put the one on the left to the stones. They are white steel, and glass hard. I sharpen a certain way, so I always have to set up a chisel to facilitate that. I went with the primary angle that was on this chisel (which had a tiny rounded bevel at the end), and the primary was very shallow and the edge shattered - failed - right after working to the edge.
I noticed that the only natural stone that I have that cuts it well is okudo suita (which will cut my chinese T series high speed steel chisels). So, I reworked the bottom of the bevel a little steeper and then put the chisel to okudo suita to give it a final angle. I haven't gotten to the one on the right yet. My okudo is not a particularly fine stone (though I have never seen another stone that is its equal), but the steel is so hard that it was brought up to a bright polish.
Chisels as hard as the one on the left punish beginners, but I have a large arsenal available and a lot of experience sharpening so it's not an issue. I don't expect the chisel on the right to be any softer. I wouldn't want them to be softer, that is commodity work.
Re: UPS Brings a Surprise
Nice!
John in NM
Somehow a big Japanese slick is one of the only ones to ever seriously tempt me. That is a slick right? A bit hard to tell, but looks like one between the envelope it sits on, the handle, and the overall shape.
What are you going to use it for? Is it small enough to shave down a roughed out plane bed?
Re: Nice!
david weaver
I think they look bigger than they are. They are probably a foot long or a little over. One's 36mm wide and one is 24mm wide. I will probably use them some for planemaking, but also for joinery.
Allen Fulmer
If these are what I think they are, Ive seen these on a certain website. Very nice.
david weaver
They are what you think they are. I only got them because of someone's generosity (that's an understatement) and I'm very privileged to have them.
Allen Fulmer
I can only imagine you're thrilled to have them. I know I would be. Ive long drooled over the 2nd gen Ichihiro shinogi slick. If i could find that thing...
Im on the fence about getting a set(7pcs) of Kiyohisa push chisels. Im just trying to decide if I really need a set of push chisels.
david weaver
I generally like western parers for furniture, because if I am using them to clean tenon shoulders, I always seem to wear corners of chisels fast and just want something that sharpens easily.
But I will tough it out to use kiyotada's stuff!! :b
If I were in your shoes, I'd wait on the push chisels unless you really want something specific and know what it is. Trading around japanese tools quickly is a good way to lose a lot of money, especially if you buy them new.
