Re: Shooting Board
I have a little problem with my shooting board. I get tear-out on the back of the piece I am shooting. Why is that?
I made it several years ago with some scrap Cherry 3/4" plywood. The top piece of ply has a piece of Ash glued to it for the plane to run along. The backer piece is a scrap piece of Walnut.
Everything is square (the Walnut piece is adjustable). When I shoot a piece and check it with a square, it's square, but there's (almost always) a little tear-out on the back.
Hi Joe
The "tear out" is called spelching. This occurs when there is too little support at the end of the board.
Imagine that you were planing endgrain in a board held vertically in your face vise ... you would either add a backing board to the far end, or you would chamfer that end, both to avoid this spelching.
The shooting board is no different. It is simply a controlled planing of end grain. If the end of the board is unsupported (that gap that you refer to), then spelching is likely to occur. The gap simply develops over time when the blade is projected a little further than usual - it is really not reasonable to expect that the end of the fence remains untouched over time, that is, that it will stay the same length.
You could replace the fence, but I consider that this is unnecessarily time consuming.
You could use a fence that may be adjusted to the ideal length. This is a good idea when building a board. Here is one like that ...
Better practice is to simply add a chamfer to the rear of the board. That way one learns not to rely on the fence as a backing board. Below is an example (exaggerated).
Butt the end of the board against the fence and chamfer the end with the plane on the shooting board. This assures a square chamfer.
Now turn the board around, rest the reference side against the fence, and plane to the end of the chamfer.
