New WoodChat!
ADVERTISE HERE - FREE TRIAL
Convex blade spokeshaves?
Denny
So I'm working on this cabinet with walnut legs, and I thought it might be good to add some texture to the legs. I'm thinking about trying to do it with a convex blade shave. The only ones I can find are Kunz, Clifton, Emmerich, and a small bronze spoon-bottom shave from Lee Valley.
If the project were smaller I'd think about using a carving chisel, but the legs are over four feet long.
I've never worked with a convex blade shave. Is this a fool's errand? Any advice? Any experience with any of these shaves? Should I just stick with the carving chisels?
Thanks,
Denny
Re: Convex blade spokeshaves?
Jack Guzman from Maine
Denny,I'm not sure what you are looking for but spokeshaves are good for shaping chair legs. I have and use quite a variety of them,including concave. They are very easy to use and most are good for sneaking up on a shape,taking only as much material as you want. As to the ones you mentioned,I don't have any of them. I do have a Lee Valley round bottom shave that works quite well. Also I have a "concave"or curved in both directions shave called a travisher .I use it for hollowing chair seats.I don't think that is what you were thinking of though. I think for creating a textured surface on chair legs almost any shave will work.The round soled ones are better for inner curves.I hope this helps .---Jack
Why not a scraper?
You can get curved hand scrapers, in a couple of different styles (I'm using Lee Valley's examples because I'm familiar with their website, but other people have them, too): http://www.leevalley.com/us/wood/page.aspx?cat=1,310&p=41069
(or, if that doesn't work, http://www.leevalley.com/us/wood/page.aspx?p=32639&cat=1,310,41069&ap=1 and http://www.leevalley.com/us/wood/page.aspx?p=67392&cat=1,310,41069&ap=1).
You could file your own from a piece of old handsaw blade, wide bandsaw blade, or similar stock. If you're interested in texturing, you could get right creative with file-your-own shapes: curves, V shapes, etc.
Denny
Jack, thanks for the ideas, but I'm really trying to add lots of texture, not shape. I did try with some regular shaves, but found that even a round bottom shave with a straight blade doesn't really accomplish what I'm trying to do.
Denny
Re: Why not a scraper?
Denny
Bill, I might try using a scraper, but I think it might be even slower than texturing with a carving gouge. I spent some time last night playing with a gouge, followed up with a flap sander and it gave pretty good results, it just takes a lot of time. I'm still picturing that using a shave with a curved blade would work like a large gouge. Almost like a very short scrub plane.
Denny
Re: Convex blade spokeshaves? *LINK*
I have one of these and it does make scooping cuts.
convex sole block plane
Denny
Thanks, that's more what I'm looking for. I also noticed that Lee Valley has a double convex detail palm plane that might be useful.
palm planes
Please post pictures
Your idea sounds intriguing. Don't forget to post some pictures here - progress pictures, or pictures of the completed project, or both. Since you have a profile, if you've got a digital camera, you should be able to post pics directly from your computer.
Re: Please post pictures
Denny
Bill, I'll try to post some photos if I make any progress. Main think I've accomplished so far is to start testing some options for finishing, I'm probably going to be pre-finishing before glueups.
TomD
If it is straight a round would work. For compound curves:
Denny
That's cool. I'm guessing you made that?
TomD
Nice plane. I think that was made by the owner, but it is very similar to a plane regularly in production by the Crown Plane Company. Or may be one.
I make a few planes, and have for a long time, but for some reason I shy away from the compound curvatures in that kind of compass plane. Probably easy when you get started.
