New WoodChat!
Easy plane blade back flattening
Chuck Bjorgen
Earlier this week I brought home another No. 4 Stanley found on Craigslist. I started the blade back flattening chore the hard way, the one that is rough on fingers and not very productive. This cutter had a rather pronounced belly that would not easily go away. David Weaver in his “Making a Wooden Plane” video series showed his jig that helps with the flattening of plane blade backs. Remembering David’s jig, I threw my own version together this morning and was simply astounded at how much easier this chore became for me.
I used a chunk of 2 x 4 that I’d flattened and 5/6” bolts and nuts with oversized washers. The bottom holes were inset with a Forstner bit to keep the bolt heads and washers from riding on the work surface. I used a series of DMT X-Course and EZ-Lap diamond stones for about 15 minutes to complete the job. During the week I might have spent a total of an hour getting sore fingers but no results without this jig. The beauty of this jig is that it seems to concentrate all your effort onto the blade and stone. Thanks for the tip, David.
Here’s my version:
Re: Easy plane blade back flattening
How does it work?
Does it provide you a larger handle, or is there some other magic at work?
Re: How does it work?
Chuck Bjorgen
Hi Bill -- I believe it allows the full force of my shoulders and arms to exert pressure right where it belongs, directly on the blade back and stone. When I try to flatten using only pressure from my hand and fingers, it's just not as effective. In his video David suggested applying full pressure directly over the stone and that's what I do.
TomD
Been doing that for decades due to this photo:
I think there was a cast iron version that used to be in tool catalogs. Good implementation to make use of the blade slot though.
david weaver
Glad someone is using that. It's better to have tired triceps than bloody or arthritic fingers.
I mentioned putting hands over the iron because I originally was testing coarse rasps and rounded off the ends of my stick of wood and quickly found that with hands out on the ends, it's easy to roll the end of an iron and create a problem to deal with.
I probably have the book that tom's picture came from, but I didn't get the idea there, I got it from seeing a japanese blacksmith sitting working an iron on a very large waterstone. He had a wood block with a wedge on it to hold the iron.
One with hose clamps could be used for non slotted western irons.
