New WoodChat!
Traditional M&T Joint Chinese Style
Chris Scholz
Chris Scholz
Last week I posted a link to my favorite woodworker, 辛师傅 to Youku. Looks like the link does not work too well, I think it is because this was going to google translate.
Ok, so maybe I'll process this a bit and make it more accessible for us in the West.
First, hand-cut M&T Chinese Style. 辛老師 (as a Professor, we need to call him 老師, i.e. laoshi, the title 师傅, shifu, is more for skilled craftsmen) is doing this a bit different than what Prof. Ecke shows in his book "Chinese Domestic Furniture", joint #10a, #16, and to some extend #25 and #32.
My on sketchup rendering.
Wonder if the two miters are cosmetic or to support the M&T. My limited knowledge in mechanical engineering in general and statics in specific makes me think that the miters help prevent racking. Thinking of it a bit more, this is an ingenious extension of our own M&T joint (or maybe our M&Ts are a crude simplification of the Chinese M&T joint, or maybe Western M&T joints and Chinese M&T joints were developed completely independent from each other).
In any case, here's a link to the original video on Youku (without the google translate part), should work this time...
http://v.youku.com/v_show/id_XNzc2NzAzMDQ0.html
(Hmm, have not figured out why the link starts t 7:31 min into the video, just scroll to the beginning if you are interested in this)
Enjoy.
Re: Traditional M&T Joint Chinese Style
William Duffield
At least one reason the miter is used is so you can put a radius or more complex molding detail on the front (and back) faces of both parts and have them still meet smoothly at the joint.
There is a practical advantage
Looks like a great joint for those no longer challenged by a western M&T :D
I see a practical application. If the face is not flat some sort of miter is essential at the intersection of two pieces. I solve the problem by covering up the western M&T with a facing strip with the profile, in this case a section of a circle, and miter the two applied facing pieces together with a "dart". The Chinese joint illustrated would similarly solve the problem without resorting to the applied facing. However, I have no idea how I would approach reliably cutting the Chinese joint.
As an aside I don't see that it has any racking advantage over a western shouldered M&T.
Re: There is a practical advantage
William Duffield
That's exactly what I was trying to describe. Thanks for the photo; I couldn't find one. That joint also works if instead of a curved face, you want a bead on each edge of the stile and blade.
David weaver
I like the wall of plane bodies behind his bench. I presume he made those because there's no damage on any of them.
Re: For example
William Duffield
I wonder why he fit it so well at the bottom, but just butted the molding at the top?
answer
see picture
BTW, the "he" is me.
Re: answer
William Duffield
If I'd seen that picture first, I would have known it was yours because I would have immediately recognized your fine line and berry work, and I wouldn't have needed to ask my question. The way you did the moulding looks good. I think another bead above the top drawers would have looked too busy.
Can`t decide what I enjoy most about these videos
Bob Hackett
It `s either the fact that he never lets anything get in the way of the work (he can pretty much wrestle anything into submission) or the fact that he has such a fine sense of fashion (eclipsed only be his demonstrated skills as a woodworker).
This guy is both incredibly inspiring and also removes all tool related excuses for not getting the job done. A vice chaser of the highest order. :D
Chris
I have no clue what these planes are about. They don't show up in the old videos for sure, will be interesting to see what happens.
TomD
Chris, have you ever come across a video on how to make one of those bowsaws, or seen them for sale. I made one out of Purpleheart a long time ago, but have never been all that pleased with it.
Chris Scholz
yes...
Chris Scholz
I remember having seen a video where he makes a bow/framesaw from scratch. The thing that I thought was very different is that he set the teeth one left, skip one, one right, skip one, ...
Will start a new thread when I find the video.
Re: yes...
TomD
Thank you.
