New WoodChat!
cleaning a carving
cleaning a carving
Jack Guzman from Maine
cleaning a carving
In 1950 my Aunt Marie was an army nurse based at Ft Lewis Wash.While there she took a woodworking class and built a walnut coffee table with a beautiful rose carving in the top. I remember that table in the living room of my grandmother's house. It had a piece of glass covering the carving so it is fairly pristine.
When my aunt died my sister ended up with the table. Some friends visiting her sat on it breaking some of the trim off.They tried to repair it by nailing it back on.They broke off pieces of the trim in the process. The legs also got damaged.She put it in storage and it sat for years. I just recently got the table and I'm putting it back together.
The legs are a simple fix. Just a little glueing needed there.
I scraped the broken surfaces of the trim pieces and applied some stain to make the damage hard to see.(I don't have the broken off pieces)I will predrill and nail them back on. The top was coated with dust. Most of it wiped off easily and I figure I can renew the surface with a little wax.The finish looks fine.My problem is the dust in the cracks of the carving. I did some wiping with rag edges but I can't get it all. I was thinking about mineral spirits and q-tips but I'm looking for ideas.
The carving is deep. In some places,the stem for instance,the carving is separated from the block.thanks for looking---Jack
Re: cleaning a carving
air compressor
90 psi and a fine tip. You might need to tease the deep cracks with the tip of a thorn or something similar that will not scratch the wood. Pipe cleaners can be useful. Ditto stiff bristle small brush like an "acid brush" (I think that is what they are called).
Doug Trembath
I found that a good quality nylon paint brush and a bit of household cleaner will reach these areas pretty well. Follow that with compressed air if you can, and any remaining gunk will exit quickly. I use budget window cleaner for just about anything that doesn't need bleach around the house, so I'd probably use that. Shouldn't affect the finish if you work it quickly and dry it as soon as possible. Can't hurt to try, I suppose. It may help to do small areas at a time, patiently.
Doug Trembath
Be Careful!
Paul in NJ
If the finish is shellac, any cleaner containing ammonia or alcohol will affect it. You should test in a hidden area first.
Paul Dzioba
Re: Be Careful!
I'll keep that in mind.thanks---Jack
Re: air compressor
I hadn't thought of compressed air. Great idea.---Jack
I'm going to get some help from my wife. She has the cleaning supplies.thanks--Jack
Tony - Memphis
I get some help from my wife with these type sof things as well...she is an artist (oil painter). When her brushes wear out, I get them. I cut them down and they make great "brushes" for glue spreading, cleaning crevices like your carvings, etc. the bristles are usually soft enough to not scratch but firm enough to clean. I doubt air will get all of that out. I would test any cleaning solution before I did the whole thing. Don't forget about good old soap (like Murphy's). In the end, you may not be able to get it all out. In that case, I would use a dark wax to color what's left and add a little sheen to the rest.
Tony
