New WoodChat!
cutting holes in uhmw plastic
les winter
I need to cut some holes in uhmw plastic to act as a bushing for my leg vise. 3" od, 2-1/2" id. 1/2" thick. Can this be done with hole saws? Any other suggestions would be appreciated.
thanks.
Les
Re: cutting holes in uhmw plastic
Doug Trembath
Les, UHMW and HDPE machine quite well with woodworking tools. Hole saws work but be sure to secure the work, because you get strands of waste material rather than dust, and they can get caught up in the kerf, or wrap around the tool. This can cause unpredictable and sometimes hazardous behavior. DAMHIKT...
I routinely use modern materials for shop applications. They don't work that well with hand planes in my experience, however. Using a smoother to reduce the height of a block wasn't all that acceptable for me. Others may have had better success, though. I got a lot of chatter when I tried it.
Use caution, again, and clamp the work well, take small bites, clear the waste often, and you can make it happen if your expectations are reasonable and your approach circumspect.
Doug Trembath
les winter
Thanks gents.
Screw it to a waste block on faceplate of lathe.
Keith Newton
Then all you would need to do is plunge a parting tool through on your lines. It will turn like butter.
But another suggestion, may be to switch to PVC. You can probably find a scrap or fitting that works.
Bob Hackett
Been my experience that drilling plastic tends to be "grabby" in much the same way that drilling brass or bronze acts. I`ve had more luck using tools that scrape rather than cut to get the job done. Think of putting a micro bevel on the cutting edge of the hole saw teeth or drill bit that turns the cutting edge into a scraping edge. I`ve found it makes cutting holes in grabby stuff (technical term) much more controllable. Make the modification small enough and you`ll have no problem resharpening back to normal.
thanks.
Les, UHMW is wonderful to cut with a sharp edge. I do mean sharp. Drill it, plane it, chisel it ... effortless, friendly.
I plane it on the shooting board or with a block plane. It creates long, transparent shavings. Ditto on the lathe.
Just last week I turned a section for a plane hammer.
This is just a smaller version of what you plan to do.
Just ensure that the hole saw teeth are sharp - touch them up with a file to be sure.
les winter
Thanks for the great replies.
