Clarification
I imagined this technique being used in rare situations like applying a molding where one wants the position to be fixed while diddling with other issues in the application.
But apparently some are using it, or thinking of using it, for panel glue up? I would never advocate brads or anything else for panel assembly. There is no need.
If anyone has become dependent on salt to be able to glue up a panel I will not be able to convince them to abandon this approach. But, I would encourage anyone learning to not travel this path. Only a tiny fraction of panel gluers (I would have thought none) rely on this aid which has the real risk, if overdone, of screwing up the glue.
Skidding boards results from some combination of improper alignment of clamps, too much glue in the joint, or inexperienced clamp tightening procedure. Learn how to position the clamps straight, apply just enough glue to get a tiny amount of squeeze out and tighten the clamps a little at a time while adjusting board position and keeping boards in position to get the glue to make the initial tack. Once tacked, and this is quick with the proper amount of yellow glue, the clamps can be tightened with abandon.
