New WoodChat!
SJBTCO Infill Project
CJ in MPLS
So I'm nearing the end of a lateral file cabinet project and am contemplating my next endeavor. Given the problem$ I've been having keeping the garage warm, I'd like to contemplate some time spent in my company's tool room.
I've got the rough casting kit for the coffin sided smoother. There is to be no adjuster.
I've got a small set of end mills and access to a lathe and a Bridgeport mill. I've also got a bad record of screwing up small chariot plane castings. what I plan to do is to chuck the casting up in the lathe and skim the bottom more or less flat, use this as a reference surface to true up the sides and then iterate this one or two more times, each time taking small amounts, to get to a flat and square plane body. The curved surfaces will be addressed using a disc sander.
This may or may not be the best approach, but I think I'll end up with a flat and square body. At worst I may end up with the actual surfaces rotated a bit (around the longitudinal axis of the body) from where the nominal bottom and sides should be. However if I'm careful, I should still have enough meat left at the mouth to get a good fit. This brings me to the real quandary. Having not worked with a casting like this before, I'm curious as to how one opens a mount in a smoothing plane casting so as to form a solid and true bed? The wood part I'm not sweating (other than my allergies to cocobolo and the like).
Got any insight or references I might need?
CJ
Re: SJBTCO Infill Project
BrianMonumentCO
Out of curiosity, why are you not planning on placing the casting in the vise of the mill and milling the bottom flat?
CJ in MPLS
I shall. However, I will not do so all at one time. This is to avoid the problem of going too far without appreciating the problem. Having had this happen to me once before, I'm keen to avoid the problem. More work I suppose, but better than having to replace the casting.
Wiley Horne--So. Calif.
Hi CJ,
You go back far enough that you may remember this on your own, but I'll mention it. Long years ago, Stephen Thomas built a Norris 51 from a SJBTC casting, and wrote up the process in Home Shop Machinist. He also said quite a bit about it on Badger Pond, if you happen to have the Badger Pond archive CD.
Anyway, I did a quick search and SJBTC is selling the SMThomas three part series in reprint from Home Shop Machinist. Not the same plane you're building, but there might be some good learning in there anyway.
Scroll down through the videos until you come to the Stephen Thomas entry:
http://www.stjamesbaytoolco.com/videos.html
Wiley
CJ in MPLS
Thanks! I'll look into that. I never did purchase the Badger Pond CD, though I should have. I, like many of you, migrated over from that site when it closed.
CJ
TomD
Basically you set the plane at an angle, cut back and forth square, with say a dovetail bit, that will leave you with more options for opening the mouth. Or if the plane is huge, or you can't hold it, you do the opening with the head angled. But since that means every step needs to be cut at a different depth, I prefer to jig the plane.
A little cut through from the bottom helps in most cases.
While you need the bottom flat, you may want to leave some features on the outside that might allow you to hold the casting, and do the inside first. examine what you have to work with before flushing it all off.
Re: SJBTCO Infill Project *LINK*
Bruce, a MN Galoot
In the beginning years of the oldtools list there was a group build of the SJBTC smoother. You might try those archives for whatever info there might be.
Oldtools archive
