a word on smoke fitting
bridger
https://bridgerberdel.wordpress.com/2014/12/30/a-word-on-smoke-fitting/
bridger
Re: a word on smoke fitting
John in NM
Old gunsmith's technique, for fitting a barreled action to the stock. I've also heard of using lamp black in oil as an alternative to the flame. Patience is the word, either way!
bridger
Or prussian blue, or china white... I've used graphite pencil, crushed up lumber crayon, carbon paper....
TomD
Cool, this is also how I fit blades in Japanese planes, used all kinds of stuff. It isn't as definitive as one might like. At times you can remove just the inked part, but you really have to look ahead at what the smoke is telling you so you can jump ahead and remove not just the one point but enough to proceed at a reasonable pace. With metal it really is a mater o scratching off the actual marks, though even there you can go to different depths, plus they want a surface that has points on it, while with wood we normally want a fair surface. The best way to cut a fair surface is to start cutting the shape as soon as possible.
Also the method used with surface plates. There are special inks for that. Another useful product when you don't have the right stuff is erasable markers, they leave a kind of powder on the surface.
I think smoke is probably the one thing I haven't used. They used to have a tool that burned sorta like a lighter, but with a really black smoke, probably kerosene, incompletely burned. It was for darkening sights on guns.
BrianMonumentCO
In gunsmith school they taught us how to make a lamp that burned oil.
The soot was nice and would adhere to metal and wood.
But we used it primarily for metal to metal fittings.
At least in that class.
In the stockmaking class, we NEVER used smoke.
