New WoodChat!
Gluing tagua to wood
CJ in MPLS
A long while ago I built a Limbert bookcase but cocked up the installation of the doors/lock. The doors and the lock work well, but with a small strip of wood placed over the gap between the doors, it became difficult to fit a brass around the keyhole in a way that would be pleasing to me; I just wasn't thinking ahead when I added that strip. What finally I did was to make a half skull out of tagua and use the eyehole as the keyhole.
I've had trouble getting the tagua to stick to the wood. Any recommendations on which glue to use? Also, what is a good glaze that I could use to highlight scratched lines in the tagua without dyeing the larger surface of the material?
CJ
Re: Gluing tagua to wood
Is the glue bond breaking over time or right away? I'm wondering if the problem is differential expansion. If so, something flexible, like silicone caulk, might be the ticket. But just speculating. Experimentation on test pieces would likely be safest.
Neat idea. Let's see the whole cabinet.
CJ in MPLS
Bill:
The expansion is likely the issue. I'll have to see if I have an open, uncured tube of caulk/sealant/glue about.
The cabinet (in its crowded corner) is shown below. If you look closely, you can see me peeking out through the glass.
CJ
Wiley Horne--So. Calif.
Hi CJ,
No experience here. But these folks say epoxy or CA (superglue):
http://www.wood-database.com/lumber-identification/other/tagua-nut/
I find epoxy scary when it doesn't work out right, or even when it does--gets on adjacent stuff, not to mention fingers, which then requires acetone (fingernail polish remover), which will dissolve anything organic like your existing finish, yada yada. Plus wife says what happened to my finger polish remover?.... :)
Wiley
Age matters
Silicone caulk and similar silicone compounds have a shelf life of about a year from production, something I learned after I smeared some on something and it...just...wouldn't....cure. Most manufacturers have moved, thank goodness, to open dating of silicones, either a production date or a "use by" date. Don't buy any silicone caulks/compounds on which you can't determine the expiration date; and if the date has passed, toss the product.
Also avoid the mistake I made several years ago of buying all the silicone caulk I was going to need for a large project that then, somehow, got pushed aside by other priorities, something that rarely happens in my house*. I must have lost $40 on that timesaving purchase.
*And, if you believe that, I have the deed to this bridge...
Re: Age matters
William Duffield
All may not be lost. Depending on what silicone formulation it is, you may be able to just cut the "sausage" out of the tube and use it for cleaning sandpaper (abrasive belts and pads). It works a lot better and lasts a lot longer than the crepe erasers that are sold for the purpose. If it's not the right kind of silicone, you'll know immediately when you extract it from the tube.
Re: Age matters
don stephan
Given the nightmare that silicone contamination of wood can be, I wouldn't want to try this.
