experimental plane
bridger
I'm modifying a broken block plane to be a low angle bevel down with chipbreaker one handed mini smoother. The build notes and pictures are at https://bridgerberdel.wordpress.com
experimental plane
bridger
Re: experimental plane
Lars Parrington
Cool project. I like that you are repurposing your old broken plane into a new tool. Also i'm curious about how the 35 deg bedding angle works out.
I'm curious as to how you will sculpt the infill and wedge so they are the optimal shape and angle. I'll be interested to see the outcome.
Nice project. I liked the walnut totes, too...
Ellis Walentine, Host
I have a woodie, bevel down plane that beds at somewhere around 35 degrees, on a skew. I've never had time to test it out for function, so I'll be interested to see how yours performs.
bridger
So far it's cutting pretty well. The sloppy fit of the temp/trial infill and wedge means it doesnt adjust very well and I'm not done with shaping the edge yet. Plenty more to do yet....
There shouldn't be a problem with 10 degrees of clearance (from a 35 degree bed and a 25 degree bevel).
I have a strike block plane I built that has a 38 degree bed and a 25 degree bevel ...
Closer to the configuration in question is a Veritas Custom Jointer with a 40 degree frog and a 30 degree bevel. This has performed well on both face grain (with the chipbreaker closed up) and shooting end grain ..
As far as I am aware Leonard Lee wrote that only 7 degrees of clearance was needed.
bridger
Im not looking to build this thing hanging off of the edge of practical usability. The fussiness of maintaining an edge where a couple of degrees off one way or the other means that the plane either stops working or breaks is not my idea of a fun plane to have or use.
Hi Bridger
You have no choice but to be fussy with your bevel angle as you have too little leeway for clearance. A degree here-or-there should not matter, but 5 degrees will likely do so.
bridger
A 25° flat bevel isn't too hard to do freehand as long as you're not too picky about a little rounding. Just keep the heel ground back. Pushing the cutting angle down does narrow the window of course, but it's not so tight as trying to hit the minimum. Let's see, 7° clearance, probably 20° bevel if we use one of the tough wear resistant steels, build that as a 27° bedded plane and you've got a plane that you have to get the sharpening just right to use it at all. It would be very interesting to see how such a beast would perform, but I'm not up for the constant maintenance.
bridger
I've uploaded a few new pictures and notes tonight.
