New WoodChat!
Did not auger well
Did not auger well
Did not auger well
Jason in OC
I have a noob question on using a brace and auger bit, which can be summed up as "is it me or is it a crummy bit?" The story is that I was drilling a couple stopped 7/8" holes in a beech slab. I started out with a 7/8 forstner bit in a drill guide that sort of turns an electric drill into a mini press. I clamped that rig to the slab and zipped it right down. But, the forstner wasn't long enough to get the depth I needed. So, I got a 7/8 auger (Irwin) from the hardware store and put it in the brace. The brace crank is about 5" offset from the chuck. (Is that a 5" sweep or 10"?) The bit dug right in and quickly became VERY hard to turn. As in, one hand above the chuck, one hand on the crank, using most of my strength to lever it a quarter turn at a time. This seemed excessive but it was working. When I pulled it out to check my progress I encountered the opposite problem. I could not get the bit to start again. Even leaning on the pommel of the brace with my chest and cranking, the bit wouldn't cut and the lead screw just packed full of sawdust. I eventually got it started again by roughing up the bottom of the hole with a chisel.
So, am I missing something in the art of bracing and augering, or do I just have a two-bit bit?
Re: Did not auger well
Hank Knight
In addition to what Derek said, your bit may have a coarse lead screw, designed for soft wood. Beech is pretty hard. A coarse lead screw pulls the bit into the stock quickly which causes it to take a big bite - O.K in soft wood, but makes for tough going in hard wood. Auger bits designed for hard woods have finer threads on the lead screw and take a smaller bite. It's a little slower but a lot easier going.
david weaver
My guess would be that the leading edges on the auger aren't sharp enough. If the bit that you bought is designed to be run in a power drill, it's going to be a little bit different than a vintage irwin bit would be.
I've had the same problem with good bits, but only when the wood is really hard like macassar ebony or something. Quartered maple has been problematic from time to time, too, because you can get in a situation where you're working only soft early wood with the lead screw, and that packs the lead screw and doesn't provide any pull.
If your bit is a new bit, I'd put it in a power drill instead of a brace.
T Handle
Warren in Lancaster, PA
As others have suggested you need to look over the new bit carefully. Sometimes they have extra bits of steel that should have been machined away or dull areas, etc.
At 7/8" you are getting in the range where a T handle is much more efficient. Make a handle that is about 15 inches long (or maybe the same length as the bit) out of hardwood. Drill a hole in the center and use chisels to roughly conform to the tapered tang of the auger bit. I used a maple chair leg before building my lathe.
With a T handle you can more easily deliver balanced pressure and more torque. I often have the work kind of low so I can lean into it.
Re: which bit?
Jason in OC
It says "Speedbor" on the box, but it looks like the "Power Drill I-100" in the link.
Jack Guzman from Maine
Re: which bit?
The bit you describe was designed for high speed use with a power drill.---Jack
AlanWS
To summarize what's been said:
To make the bit turn more easily, a fine thread on the lead screw (so it does not feed as fast) and a sharper cutting edge will help. If you remove the bit from the hole partway, reverse the direction first so you don't destroy the lead screw threads tapped into the wood that help feed the bit into the wood. However, augers are so much better at clearing chips than other bits, you may not need to remove it partway.
To get more leverage to turn the bit, a T-handle provides the most. In between that and your brace would be one with a larger sweep, in other words one where the handle reaches further from the axis. If yours is 5", that's called a 10" sweep because the handle sweeps out a circular path 10" in diameter. For large holes in hard wood, a 12" sweep brace would give more leverage, but is harder to find.
(Message Deleted by Poster)
may not need the lead screw
Jerry Gibbs
Boatbuilders use a barefoot auger that does not have a lead screw. The bit is guided otherwise and the bit does not wander with the grain. Electricians use the an auger bit, but I believe they use a geared and powerful slow turning drill motor.
replicates my experience
A bit and brace used to be a handy tool on the farm. For example one might need to install farm gate hinges 1000'feet from the nearest plug, or pins for corner post bracing. In wood that was not thoroughly dry 1/2" holes were readily bored in a locust post. However, for boring a larger hole in dry hard wood like maple the lead screw advances the bit at too great a rate and it is difficult to cut that deep a shaving. I believe the bits are designed for softwood, and hence useless for dry hardwood in the larger diameters.
I solved all the problems by buying a cordless drill and a variety of bits to go with it. I have not used the brace since.
Electrician's/plumber's auger bit
The bits sold for drilling holes in framing to run wires, conduit, and pipe often have auger (screw) tips, and will go through a 2x4 like a teenager through pizza. They require fairly strong (high amperage) drill motors, and you sure don't want one to bind as it's drilling; you can break a finger if you're holding the drill motor wrong, and will likely at a minimum get pretty beaten up.
Re: Electrician's/plumber's auger bit
Patrick Gibbons
I have some NOS Russell Jennings bits made when Stanley owned them. They have a course lead screw and one lip (rather than two). They do go through wood like cr@$ through a goose.
Bits came in three lead screw threads. Course, medium and fine. The common bits were slightly oversized. Many are unaware of this until they find out the hard way. DAMHIKT. A fine lead screw will drill through hard wood easier but they are harder to find. At one time bits were made in about a bazillion different iterations.
And then there are double-lead-threaded bits *LINK*
Some discussion of the double threads on the lead screw below. I know only what I've read of them, and have no idea if I even own any with double threads.
http://cornishworkshop.blogspot.co.uk/2013/02/lead-astray.html
and the link below
http://www.sawmillcreek.org/showthread.php?131238
