New WoodChat!
Found tool
Found tool
Found tool
CJ in MPLS
For kicks I dug out an old box of tools that had been given to me a few years ago. For the most part the box had some of the most clapped out turning tools I've ever seen, but it also had the tool below, fashioned from a file:
The outer edge of the hook is or was sharp. The inside of the hook is not sharp. I have two of these, one without a handle though it may well have had one. It too is fashioned from an old file. I bring this up in case the whatsit is used in pairs.
Any ideas what this is?
CJ
Re: Found tool
Re: Found tool
Timothy
I would take a wild guess that it is some kind of a "primitive", hand-made (meaning self-made) chisel. Chisels come in a variety of forms and shapes. Here take a look:
http://toolmonger.com/2007/12/10/get-bent-buy-a-swan-neck-chisel/
http://www.scienceclarified.com/Ga-He/Hand-Tools.html
http://www.fullchisel.com/alburnam11.htm
Re: Found tool
Re: Found tool
Larry Barrett
If it was a turning tool, I have no idea. But if you were chopping mortises by hand, a tool like this could be used for clearing chips out of the mortise.
Re: Found tool
Re: Found tool *LINK*
Stuart Johnson
Possibly a custom made scraper for the inside of boxes and hollow forms.
Hooked Scrapers
Re: Found tool
Same form, but no ticket
CJ in MPLS
The only part of the tool that is sharp as I would expect a chisel or a scraper to be is the very point, which comes down to a knife like tip. As a result I'm not certain that it is even useable as a chisel or scraper. I'm guessing some sort of parting or marking tool for the lathe, but that is pure speculation on my part.
Re: Found tool
To me it looks like
John in NM
A homemade tool for scraping grout or mortar out from tile or brick.
Re: Found tool
Re: To me it looks like
CJ in MPLS
You may be correct. However I shudder to think that I've now got three tools to scrape grout. Someone might think to request that I do this, which would be unacceptable. Please keep this between us.
Re: Found tool
Those are definitely tools to get rid of....
John in NM
Wouldn't want to use them after all :D
Worse is a power sewer snake. Friend of mine was offered one for free when the restaurant he worked for was sold to a new owner. He figured that he didn't want to be the guy all his friends called instead of Roto-rooter when their drains clogged up :D
Re: Found tool
That restaurant must have...
...had interesting menu offerings, if they needed a power snake on hand at all times.
Re: Found tool
Re: Found tool
William Duffield
It's a captive ring turning tool.
This video wil demonstrate its use starting about 10:40:
https://www.youtube.com/watch?v=B0AxUJ2CWS0
Re: Found tool
Re: That restaurant must have...
John in NM
Well, it did.... but the snake had more to do with the ancient clay pipes in parts of the building and joints to plastic pipes elsewhere, joints that leaked and encouraged root invasion :D
Re: Found tool
Re: Found tool
CJ in MPLS
Excellent! The grout scraper idea was highly unsatisfying.
Re: Found tool
Re: Found tool
William Duffield
Anyway, a scraper doesn't work on grout. The grout is much too abrasive for steel cutting tools. Use a carbide or even a diamond grout rake, for example this manual one:
http://www.theamazingtileandglasscutter.com/prodimages/GROUTRKTCLS100h.jpg
or this powered one, for a Fein Multi-Master:
http://www.woodcraft.com/Images/products/600/814848.jpg?rand=862232884
Re: Found tool
Re: Found tool
JDK
Very cool.
