New WoodChat!
screw terminology question
What is it called aligning screw slots in one direction?
Re: screw terminology question
Some folks refer to "clocking" screws
Re: screw terminology question *LINK*
Bob Entwisle in NJ
Hi Bill,
As Bill H said, that is called 'clocking, or sometime timing, but clocking is the term I remember.
Plenty of references to it online, Google "clocking screws"
Gunsmiths and machinists and of course OC woodworkers practice the art.
I have to say it does look spiffy.
Bob in NJ.
Clocking Screws
BrianMonumentCO
Many of the really expensive shotguns have clocked screws.
Yet it is not really clocked as much as it is alignment with engraving.
So in a shotgun if there is upper crust engraving the screws are engraved also and they must be aligned.
Not only that but the screws are one hole only..... IE they fit in only this hole and no other.
To a gunsmith they are an extra level of PITA.
TomD
Main thing though these days is that slot screws are on the outs in a lot of woodworking supply stores, and you need an impressive collection of screw drivers if you go down this road, and want everything to be a slot screw. With a lot of the brass screws one only gets one shot at them, and they can't be replaced. Bronze and steel are more usable.
I cut my own screwdrivers out of drill rod. I just eyeball it on the grinder, but now that I have a mill I can cut the ends more easily, and using carbide bits one can cut allen key stock that is hardened.
John in NM
My dad used to call that "blousing", but I believe that was a pretty old term. He likely picked it up at gunsmiths school in the 1950's.
To my eye it's best reserved for engraved heads, as Brian described.
James Heaston
So I suppose I'm the only one that does it to switch cover plate screws? :\
There's a name for that.
Doug Wolf
James, I thought I was the only one that did that until I ran across this definition.
Noun 1. anal personality - (psychoanalysis) a personality characterized by meticulous neatness and suspicion and reserve; said to be formed in early childhood by fixation during the anal stage of development (usually as a consequence of toilet training)
Nice to know we're not alone. :)
Actually, it's a subtle sign of quality. I've tried it once or twice, with the inexpensive cover plates, and wind up cracking them; so I've given up. Good on you that you've learned how to do it without cracking the plates.
No, I've heard of others who do...
John in NM
Can't say as I would ever bother though. After a few hundred it just seems weird to waste the time on it.
I do carry a 6" square around when installing outlets and switches, because I like them to be plumb. A crooked outlet you can see across the room and looks very shoddy.
No, I do it to all screws
I think slots were made to orient in the gravitational field.
Re: No, I do it to all screws
Hank Knight
A revelation! Gravity pulls all the screws I'm working with off my bench onto the floor. I never knew it was the slots causing the problem. :D
No, no
It is the black hole under the bench that said screws disappear into that pulls them off the bench.
Re: No, no
Hank Knight
Ah! That explains why they always roll UNDER the bench where I have to get down on my hands and knees to fish them out.
Watch for some of my socks while you're there
I know they go somewhere...
