New WoodChat!
Wm. Ash & Co. Cast Steel Irons
Wiley Horne--So. Calif.
Hi All,
I have a historical inquiry....Some time ago, I came across a set of plough irons, 1-8, marked Wm. Ash & Co., and immediately below the name, 'Cast Steel'. The mark is deeply incised, so that the actual letters are embossed.
A post by Don McConnell on OldTools indicates that Wm. Ash & Co. was a Sheffield maker, and that the mark had a long history, starting with the original Wm. Ash in the 1820's, but continuing with successors in interest until 1965.
I'm trying to get an approx. date range on the irons, and the Wm. Ash mark doesn't help a lot. Does anyone know an approx. time span when the 'Cast Steel' designation was in use in Sheffield? [Dunno if this is a useful indicator, but the No. 1 iron is a true 1/8", as opposed to the approx. 3/32" you often see.]
Incidentally, I'll be having these irons up on a Benefit Auction in the next month. They fit Mathieson ploughs like a glove.
Wiley
Re: Wm. Ash & Co. Cast Steel Irons
correction
5/32" in the above, not 3/32".
Warren in Lancaster, PA
Cast steel was invented in 1740. It was used for plane irons from that era until at least the 1920s. I am not sure that CAST STEEL was actually stamped on tools in the 18th century. Off the top of my head I recall stampings from about 1820 until the early 20th century. I don't think a cast steel stamping by itself is much help in dating a tool.
Thank you, Warren
I'll have photos of these irons up in the coming days, and perhaps that will be of some help. I was thinking of the font used in the 1-8 numbering on the irons, but then I looked at some Butcher irons which I believe to be fairly old--they have the W [crown]R mark, and they have no numbers at all! Maybe numbering was a later practice!
Wiley
