New WoodChat!
Ellis, how do you install side-hung runners?
"PS remind me to discuss how I install side-hang runners sometime."
Well, you did ask for it :)
I never use side hung drawers but I might if shown how and the advantages.....which are obvious on this plan.
I am reminded that 18th century construction was developed to hold together 18th century design. There is no reason to think it best for 21st century design. After all, Krenov developed unique construction details to accommodate his unique designs.
Re: Ellis, how do you install side-hung runners?
As did Sam Maloof with his leg joint.
Let's see it, Ellis! :)
Bruce McCrory
I think we have our answer... He doesn't. (Taunt.) And, I was hoping to review a successful method. Grey (or, white, in this case) hair always has more credibility than some "young punk kid" blazing in flaming red top-knot.
I asked for it
It's actually a pretty simple trick, and you may already know it, but here it is. (NOTE: This method is for the typical cabinet with parallel sides and nominal 1/16" spacing around all the drawers. Derek's proposed case will require a custom approach because the inside will be curved or tapered.)
1. Build the case. Make it of uniform inside width, i.e., parallel sides.
2. Make the drawers. They should be exactly 1/8" narrower than the case opening and the heights should be such that when they are all stacked in the case, there will be about 1/16" space between them and at the top and bottom of the case opening.
3. Groove the drawer sides. The size (height) of the runners will vary with the scale of the piece. For something like a chest of drawers, I typically use 3/4" high runners. A jewelry chest with delicate drawers might have runners half that height or less. I usually make the grooves about 1/4" to 3/8" deep, depending on the thickness of the drawer sides, thinner on those little delicate drawers.
When and how you groove the drawer sides will take some planning and a design decision. Often I wait until the drawers are completely assembled, then I rout them on a router table, stopping the groove somewhere close to the front of the drawer. I generally leave the groove round where it stops because that look is okay by me; you might prefer a squared out groove and a square-nosed runner.
If the drawer face will overlay the cabinet, you need to rout or plough the grooves prior to drawer assembly. This is the way to do it if you are attaching the sides to the face with sliding dovetails, for instance.
4. Make the runners. Plane hardwood runner stock to thickness equal to the finish height of the grooves. They should be a slop-free slip fit in the grooves. If the runners will have curved fronts to match your routed grooves, square off and round over one end of your runner blank. Then rip the individual runners from the blank and hand plane a finish surface on one face. The thickness should be such that when installed in the drawer, the drawer/runner assembly is a snug fit into the cabinet opening. Countersink the runners for as many screws as necessary, typically three or four. If the carcase sides are solid or expected to move with the seasons, slot the rearward screw hole(s) accordingly. I used to have a cutter that would rout countersunk slots on my drill press.
5. Install the runners. Start at the bottom of the case. Place 1/16" shim strips in the bottom corners of the case opening. Prepare strips of wax paper a couple inches wide by the length of the drawer side. Position a strip of wax paper over each groove and press the runners into the grooves and flatten out the surrounding wax paper against the sides. Smear a thin film of glue onto each runner and carefully slide the whole magilla into the case, pressing it down to the shims on the bottom and making certain you don't push it too far into the case. If the case sides will move (and the runners are slotted to accommodate), only put the glue on the front half of the runner.
For flush fronts, the faces should stop exactly flush with the case sides or a little bit proud, so you can plane them flush after assembly. Repeat this process, with another set of shims, for each successive drawer until you've installed them all. Use tabs of duct tape on the top edge of each drawer to act as temporary pulls. Let the glue set for 15 minutes or so and then pull out the drawer, remove the wax paper, and install the screws through the runners into the sides.
This method assures that your runners are positioned exactly where they need to be relative to the drawers. If you try to install runners just by measuring, or even with a spacer jig, you're likely to end up with drawers that bind or are cockeyed in the opening.
Now, here's my totally speculative way that I'd consider building Derek's dresser: Make the case sides straight, from 2 1/2" thick frames bandsawn to the outside curve and straight on the inside. The drawer fronts would be full overlay, or, if he wanted the case sides to read, rout out an inside curve in the frame to the depth of the drawer faces. That curve wouldn't have to be parallel to the outside curve; in fact, it would look nicer if it flared at the top and bottom.
This way, there would only be one angle for all the drawer sides. If you didn't like the idea of drawers that sloped on the inside, you could make them perpendicular on the inside and sloped on the outside. They would be sliding-dovetailed into the faces, or the faces could be attached to separate drawer boxes. Then, grooves would be plowed at an angle into the drawer sides so the runners themselves would be level. The face of the runner that mates with the sloped case side would be ripped at a matching angle and planed until the fit was perfect, then installed as outlined above.
I know, too much coffee today. Anyhow, there's my method and a wild suggestion for Derek.
It would make a dandy Article for the "Articles"
Clint Searl
Formica samples make great shims
