Long shot
Wiley Horne--So. Calif.
Hi Patrick,
If you force the inner shim, you'll likely get distortion up through the whole sandwich.
I'll just relate a story for what it's worth, and you can decide if it fits your situation. I had a gouge-sharpening wheel, whose mounting hole was 12mm, compared to a Baldor 6" grinder with shaft 1/2" (12.7mm). You could mic these things and find out the real numbers for your case. The 0.7mm difference amounts to almost 1/32" in the diameter, which meant I needed to ream just under 1/64" from the circumference of the wheel mount hole.
Goal: Ream out the shim to 1/2" (in the example). I took my sharpest 1/2" drill bit and--by hand and slowly--reamed out the 12mm diam. wheel. The drill point self-centered in the hole. It had to bite 1/64" from the inner surface of the wheel mounting hole. The key was to keep the thing I was reaming square to the drill. I did this by fixing the drill in a vise, with wooden v-blocks either side to hold it steady. Then wound the wheel onto the drill slowly, keeping it square.
Result: In my case, the inner core that I was drilling was some paper compound, and the wheel was integral, so the drilling did not distort the mounting hole. It worked fine. The hardest part I see in your case, if you were to try to replicate this, would be to keep the shim from distorting during the reaming. And if you kept it in the wheel sandwich, it would likely spin.
Anyway, that's my story. Consider ways to ream out the shim without distorting it.
2 cents.
Wiley
