New WoodChat!
2d finishing nails or similarly sized brads
I'm looking, so far without success, for hot dipped galvanized or stainless steel finishing nails in 2d sizes, or similarly sized brads of the same composition, to install some exterior molding and trim.
I've found brads in 1-ounce packages, but the per-brad price is way too high; I'm looking for a one-pound box of them. I found listings online for 2d finish nails, but, when I called the companies, the listings turned out to be out of date or otherwise imaginary.
So far no success otherwise; I think air nailers have pretty well destroyed the market for small exterior finish nails. Maybe I need to buy some gun nails and take the strips apart.
Suggestions appreciated.
Re: 2d finishing nails or similarly sized brads
Patrick Gibbons
I'm fishing here. Tremont nail has galvanized nails. Maybe one is small enough.
http://www.tremontnail.com/tremont-galvanized.htm
Patrick Gibbons
It doesn't seem like that long ago I bought 2d stainless finish nails at The Borg in a 1lb box.
Try marine supply houses
Gun nails dissuaded....
Bruce McCrory
I tried to do that with 18 and 23 ga. nailer sticks, and a messy "no go" was the result. Mine were for indoor trim.
They could be broken down to 2, or more; but I was forced to use "chisels" to separate them, and herding flying darts was a lost cause.
How to separate "nailer" nails from the stack
A pair of diagonal cutters does nicely if you only need a few dozen.
Re: How to separate "nailer" nails from the stack
Bruce McCrory
Our cutters have been badly mangled due to shortening fake flower stems, so couldn't assess the efficacy of said tool.
Don't know about your tool, but my diagonal cutters separate the nailes that are for my brad nailer just dandy. This is not a theoretical capability. It's how I make brands that are hammered in. I would not want to face the task of doing a pound that way, but getting a couple dozen brands is easy as snip, snip, snip (times 24).
TomD
http://www.leevalley.com/US/Hardware/page.aspx?p=40380&cat=3,41306,41324&ap=1
That's them!
I don't know why I didn't look at Lee Valley before; they've got so much useful stuff.
