New WoodChat!
Ax handle question
Ax handle question
Ax handle question
I need a spare replacement handle for a 28"- 3 pound (1.5 kg) double bit ax and don't know where to find one that will be suitable.
This is the smaller version of the double bit ax. For proper balance it requires a slender handle, a fact lost on the makers of handles I have seen recently. At a local flea market a purveyor of quality axes told me he had found one but would not sell it. He had scored it somewhere to be used to fix up an ax he might buy. He did not offer to tell me where he found it. The last one I saw was years ago at a Canadian Loggers supply somewhere in BC.
If you use, or at least recognize, a quality small double bit ax you will know exactly what I mean by a slender handle. If you know where to find one I would like the source. I have no inclination to make one.
Re: Ax handle question
Rick W
The Beaver-Tooth Handle Company lists a 28" double-bit axe handle:http://hickoryhandlestore.com/collections/double-bit-axe-handles
I've never dealt with them, just came across them when I was searching for tool handles.
Rick W
Re: Ax handle question *LINK*
The company at the link below lists a pretty extensive selection. I've never used them; online reviews are generally positive.
I sure know what you mean about the handle. I have a light single-bit axe from my grandmother that's been on the fixit list for years now, left there partly because of the difficulty of finding a handle. The right handle is the difference between dancing in dancing shoes and dancing in workboots.
http://www.househandle.com/
Patrick Gibbons
These people have a 28" handle.
http://tennesseehickoryproducts.com/products.shtml
I'm wrong
Patrick Gibbons
For retail purchase they send you to another site. The 28" is sold out but the 30" is still available.
Re: I'm wrong
Patrick Gibbons
Here's yet another Google search.
http://stores.ebay.com/Hickory-Handle-Store/Double-Bit-Axe-Handles-/_i.html?_fsub=640291010&_sid=7817160&_trksid=p4634.c0.m322
I'm just googling axe handles. Sorry I can't recommend anything.
How big is the eye?
david weaver
3 pounds is sort of a tweener size. is the scale smaller in general than a 4 lb felling axe, like a cruiser (with a small eye) or is it just a lighter axe head with a full size eye?
I think you might end up having to make it.
I think a lot of the handles made now are made heavy because it's cheaper to do that. Either that, or they're worried about someone breaking a handle trying to dig a stump out of the ground.
I don't have a cruiser, but the last handle I bought from the hardware store, I had to go through half a dozen to find one that had the grain oriented the right way. the others were candidates for delamination.
Possibility
Wiley Horne--So. Calif.
Here is a 3 lb., double bit axe, with 29" handle. Inch could be sawn off, I suppose.
http://www.highlandwoodworking.com/gransforsbrukscompetitionthrowingaxe.aspx
Do you suppose Highland Hardware would sell you a spare handle for yours? Provided the major and minor diameters of the connection end were suitable (not too small). Throwing axe--they must be concerned about balance.
I found them pretty helpful folks when I did business with them a while back. Not just order takers.
Wiley
Similarly, LN sells
this one for $29:
https://www.lie-nielsen.com/product/new-2-W-Axe-30T
Call for eye-fit measurements and if suitable, don't see where sawing a couple inches from the off-end would hurt. End is not directional.
Wiley
Looks easy enough to cut one shorter...
John in NM
And reshape the eye end to fit. The whole thing would need some lightening I bet, but that is not hard with a proper rasp - clamp the handle lengthwise in a bar clamp and hold the bar clamp in a bench vise. I shape gunstocks like this all the time.
I doubt I would try it with a $30 boutique handle from LN, but at $8 from House Handle, sure.
another Forum?
Is there a Forum where "nut cases" that still actually use an ax might hang out, or where collectors of axes hang out? What I have is a very common DB ax (actually I have 3 of them) for anyone using an ax for limbing, trail clearing, and such, or anyone collecting axes. If I can find a group that collects or uses axes they may know a source.
I have emailed the TN manufacturer to see if they will be making some anytime soon. I am sure that somewhere in Canada the handle could be found.
There is a lot to an ax handle
Study a handle and one soon sees that it is a sophisticated structure. How it tapers, where it tapers, weight distribution combine to make it ballet shoes or work boots. With the axes I use I can one-handed clip 1 1/2 to 2'' limbs on freshly fallen trees. On these smaller limbs I am about as fast as a chain saw and it is more peaceful and satisfying. But this efficiency all depends on the weight of the head and the balance of the handle. I expect I would make several handles before I got one right, and there are lots of things I would rather spend the time doing, like using the ax.
Re: There is a lot to an ax handle
John in NM
Granted you may not want to spend the time - but given the specificity of what you want, and the lack of suppliers, maybe it would be time well spent.
Once you've worked it out, you'll be able to make replacements fairly easily without all the fuss and experimentation. And the starting stock is cheap - $8 for a handle that is already "90%" of what you're after.
Jeff Weaver
Puts me in the mind of a line by the poet Gary Snyder (who I think learned it from Ezra Pound), "When making an axe handle, the pattern is not far off."
TomD
I think it is one of those things people avoid as they used to avoid dovetails because itis actually fairly difficiltn and revealing
Re: Aha, the "Blade Forum"
TomD
Or better still, youtube. Here is your forest service on the subject along with a few 1000 others
http://m.youtube.com/watch?v=Xz3rs-eaN3E
Jack Guzman from Maine
so true
I make all my own ax ,hatchet,hammer etc. handles because I'm too cheap to buy a ready made one. They are quite difficult to shape the way I want them. Usually I settle for a little imperfect but functional. If I wanted to spend the time(like I do on chair parts)I could make it perfect,but I just want to get the tool to where it can function.I think to make the handle Bill requires would be quite a chore.---Jack
John Stegall
Seymour tools online. They list a 28" handle. Of course they have a minimum order of 12 but you would have a couple of season's supply 😀
Seasons supply!
I have not broken an ax handle in memory. But I might which is why I would like a spare, or 12. thanks I will check them out
Re: Seasons supply!
John Stegall
Hey, maybe you can find ten other people looking for that size handle. Or make some stools or tables using the spares as legs. One of the most attractive stools I ever saw did just that. In fact when the company who made the handles was going out of business he bought their equipment so he could control the source. I think FWW did an article about him.
Good luck.
John
