Saw vs Saw . . .
steve mackay
Experiment this morning.
The "Suicide Saw" followed me home from the FIL's. It's almost brand new.
I'm sure this thing is good at something. One day I'll figure out what.
Saw vs Saw . . .
steve mackay
Re: Saw vs Saw . . .
No one buying a reciprocating saw should buy a cordless first. I don't yet own a cordless, but can imagine the logic, were I a remodeling contractor who occasionally had to make one or two cuts in some gawdawful place where dragging a cord in would take longer than making the cut.
That said, I, too, have done lots of cutting with a handsaw for rough cuts or as part of demolition as well as, of course, the finer cuts that require the saws most often discussed here, or their bottom-feeder equivalents.
bridger
the solution to your problem is to sharpen your handsaw. it will cut faster and wear your arm out a lot less.
Kevin French
I broke down and bought a BP'd Circ Saw when I was clapboarding the gable ends of the house. It worked very well on clapboards. Now that I'm done it might be collecting dust for a while.
Every time you recharge the battery, it will get little weaker. Every time you use your arm, it will get a little stronger.
David Churnega
Thanks for a laugh this AM.
