New WoodChat!
200+ woodworking book reviews
A Follansbee inspired Box
Paul in NJ
A recently completed box:
Red oak body with white pine top and bottom. A little transtint dye, shellac, and tinted wax for the finish.
Paul Dzioba
Re: A Follansbee inspired Box
Steve Voigt
Paul, that is absolutely gorgeous. Well done.
For folks like me who are carving-deprived, could you comment a little on the tools used (sweep sizes, incannel or out, etc.)?
Patrick Gibbons
Very nice. A great effort.
Wiley Horne--So. Calif.
That's fabulous, Paul!! What I like:
-Carving is so crisp; every detail ends in a fillip; looks like it was born there rather than laboriously carved
-It's so tactile, with quartered wood against the carving; rivet or nail head; different molds top and bottom; molds on the battens(?) reinforcing the top.
-Ageless; looks old but no signs of age on it.
Really a wonderful creation. Be sure and sign/date it.
Wiley
A few details
Paul in NJ
First, here is the inspiration from Peter Follansbee:
http://pfollansbee.wordpress.com/2014/08/17/september-is-the-time-to-make-a-carved-oak-box/
I have followed Peter’s blog for a while and have seen him demonstrate in a WIA seminar I attended. I like that he does not fuss too much and works quickly. His work has the charm of period objects I have seen so I tried to emulate his methods The red oak is riven to produce quartered stock and worked somewhat green. The front and back are rabbeted to receive the sides. The sides are glued to the front and back with hide glue and also pegged with pins from the same oak. I dried the pins a bit so that they swell some from the higher moisture content of the box when installed. The hinge pins are integral to the back. The pintle hinges are nailed and clinched to the top with cut nails. I could not find an appropriate size nail for this so I lengthened and thinned out some stock Tremont brand cut nails by heating and hammering on my anvil. The bottom was nailed on with unaltered cut nails. I am hoping the nails and soft white pine will keep the bottom and top from splitting.
Layout was done with dividers and an awl and you can still see some of the lines just like on originals. Kind of like the side of a drawer dovetail base line. I believe this type of pattern was inspired by the Gothic Churches of the period. A “V” tool cut the large arcs or “Lunnettes”. The rest of the carving was done with gouges of maybe a 7 or 8 sweep, all with the bevel on the outside or out-cannel. The large gouge I used was actually a pattern makers tool, somewhere about an 1-1/4. The other gouges were maybe a ½ and ¼ wide. Other than the “V” work the carving was done like chip carving but with gouges instead of knives. The gouge defined the radii, straight down with a mallet, and then the chip was lifted by holding the gouge at an angle and rolling it from one corner to the next. The carving went quite quickly after a little practice to get the motions right. All four pieces were carved in parallel for speed and consistency. I made a punch for the little 'daisies' from a twenty penny nail. They might be a little hard to see due to limits of picture size. After my initial carving, an experienced and trusted woodworking friend critiqued my work. I added some additional details to try fill and balance my layout.
I volunteer and demonstrate 17th century woodworking as a joyner once a month at Pennsbury Manor, William Penn’s country estate in Pennsylvania. This box and work from the other Joyners work are being donated for auction at a fund raiser celebrating 75 years of operation of the historic site
http://www.pennsburymanor.org/
Paul Dzioba
Re: A few details
JDK
Impressive effort. Bravo.
Thanks for the details.
Beautiful job, excellent explanation
