Re: Very Clean Thru Mortise and Tenon
Wiley Horne--So. Calif.
Hi Don,
Suggest:
1. Make the tenon a little long, then cut off 3/8" of it to serve as a template. This way, you're not relying entirely on measurement and layout.
2. After you locate your mortise corners both sides, lay the 'template' over them (this will help correct any inadvertent measurement slop), and pencil around the template taking care it doesn't move (you could clamp it on while pencilling).
3. Knife in the mortise outline before beginning the drilling/chopping. Set the knife gauge so that the knife is just shaving the inside of the pencil lines. If the gauge won't reach the mortise ends, then clamp a batten across the post, and knife in the ends. It is this knifing that is going to create the crispness. Make multiple passes with the gauge, starting very lightly, and use several passes to knife in deeply. It is preferable to have the knife bevel to the waste side (interior) of the mortise; in this case, start lightly and use multiple cuts, because the gauge may have a tendency to push the fence off the work, due to the bevel being inside.
4. Work from both ends of mortise in toward the middle. When done, test both sides of the mortise with the actual tenon, so you know you have fit. If it's still a little tight, use file or rasp to get the final fit.
5. [option--make shoulders within the mortise] After you've knifed in both sides of the mortise, but before drilling/chopping, use your chisels to lift out a first course, so as to create shoulders to work within for the balance of the waste removal. To do this, use a chisel the width of the mortise, and go down the mortise from end to end, making vertical chisel cuts about an 1/8" deep, every 1/8". This will break the grain of the mortise, so you're left with mostly rubble to lift out with the same chisel, used bevel down.
If the mortise outline is well-knifed, this last step is not strictly necessary, but can be helpful in avoiding slipping and over-cutting the mortise boundary by mistake.
Wiley
