New WoodChat!
Unusual 2 7/16" plane blade
Simon St.Laurent - Dryden, NY
I just bought a very used 24" wooden plane. It needs a new back handle, and the blade (Auburn Tool Company) is not in great shape, but otherwise it's looking happy for work.
At first I thought the blade was 2 3/8", but it's very clearly bigger, 2 7/16". Those don't seem to exist in replacement blades that I can find. I can clean up the existing blade if I have to, but any ideas on where to find odd size plane blades?
(No, I don't really want to buy a 2 1/2" and grind it down!)
Thanks,
Simon
Re: Unusual 2 7/16" plane blade
David Churnega
I had a similar problem with a 30" plane in very good condition (tight mouth) and wanted to get a blade and I was to make a new chip breaker. In desperation I began to look at similarly sized planes on ebay. I asked the sellers if they would measure the width of the blade. Found one on the cheap where I wanted it for the blade but now I have a 27" piece of beech that I have difficulty in throwing away. By all means try to rehab the blade you have. Some of my Auburn tools have a blade that is .170 thick and that is considerably thicker than anything that can be purchased today.
Hi Simon
If you are not willing to grind 1/16" off a 2 1/2" to enable it to fit your plane, then you could simply obtain a 2 1/4" blade and s-t-r-e-t-c-h it out. Make sure you have eaten your Wheeties.
I'd take a 2 1/2" blade to a beltsander and be done in 1 minute.
Wiley Horne--So. Calif.
Hi Simon,
Is it a tapered iron, single iron, double iron? How thick?
If parallel, single or double, you can get Ron Hock to make a replacement. I would think non-standard thickness would run the cost way high. Anyway, it's an option:
http://www.hocktools.com/products.htm
Lie Nielsen will also make custom irons for you.
I suggest Derek's or David's option.
Wiley
The joys of shifting to hand tools - I no longer have a belt sander. You're certainly right that it's a better option than a grinder.
Does a board stretcher work on metal?
Thanks,
Simon
It's a keeper
David and Wiley got me to take another look at it this morning, and clean off the reddish gunk. It's oddly pitted, but otherwise workable.
Beyond that, though, the blade is thick toward the business end - 3/16" by the bevel - and tapers to 1/16 at the top by the brand label.
It has some sad mushrooming at the top from impatient people with metal hammers, but I don't think that'll keep it from working. Hopefully it'll keep an edge. (The chipbreaker is unpleasantly sharp.)
On to building that replacement handle!
Thanks, everyone!
Simon
And I should note that Veritas has tapered blades *LINK*
Also from 1/16" to 3/16" at the bevel, though no wider than 2 3/8".
Those are 6" long, while this beast is more like 7 5/8".
Thanks,
Simon
Veritas Tapered Plane Blades
Jim Toews
In my admittedly limited experience, a board stretcher works just as well on metal as it does on wood.
Re: And I should note that Veritas has tapered bla
David weaver
You want the vintage irons and not the modern replacement, if not due to the length, due to the cap iron slot. If the cap iron is sharp and well fit, that's good.
TomD
Just make them yourself, it is almost easier than doing any of the other suggested stuff. Then you get exactly what you want. Getting set up to heat treat a whole large blade is a bit of a trick, but you actually only need to harden about 1 inch at the end, if you find you need more than that you can always break out the torch again. Not really worth it for one, but when you do that one, you will wonder why you ever waited. If my shop burned down I wouldn't spend a cent replacing anything but the saws.
