New WoodChat!
nose or nosing auger shaping
Jack Guzman from Maine
I found a nose auger today in a flea market. This is the first of this type of tool I've ever seen close up. The business end is pretty messed up.It is all rounded over and it needs a little reshaping and sharpening to be functional.The problem is I don't know what it is supposed to look like when correct. I couldn't find any decent pictures on an internet search. Anyone know where I can find a decent picture of the cutting edge of one of these tools?---Jack
Re: nose or nosing auger shaping
Larry Barrett
Jack, do you have a copy of Salaman's Dictionary of Woodworking Tools?
Salaman says that nose auger is also called a shell auger and provides a drawing of a shell auger on page 40.
Patrick Gibbons
The Practical Woodworker shows a nose bit and remarks it is a type of shell bit. Both are sharpened by filing the end. It has to be forced into the wood and should be periodically withdrawn to pull out some of the wood core. They're small, up to 3/8" hole.
The one I have is larger. I haven't measured it but it is around 5/8". It is isn't a bit but has a "t" handle permanently attached.---Jack
Show us a picture
AlanWS
Is it the type that is mostly about half a cylinder split lengthwise, but has an angled cutting lip at the end? Leonard Lee's "Sharpening" has a poor picture and says to sharpen the inside of the lip with a file. This is what Lee calls a shell auger, and Garrett Hack in "Classic Hand Tools" seems to call a nose bit.
Or is it more gouge-like at the end? What Hack calls a shell bit is also mostly a hemi-cylinder, but the cutting edge is more like that of a turning gouge with a thumbnail grind and shallow bevel. I think those are distinguished from spoon bits because the edge is part of the cylinder, rather than curved down at the end to hold soup like a spoon.
There are also tools used for cutting out the inside of wooden shoes that are T-handled spoon-like bits. These are used with considerable force, so have solid shafts and the spoon part is wider than the shaft and sharpened at the front and pretty far up both sides.
Stephen Shepherd
Stephen Shepherd
Treat it like a chisel or plane blade and get the outside flat like the back of a plane or chisel blade, albeit slightly curved, but it should be flat.
Then file the inside bevel until the edge is sharp, remove the burr. The edge should have slight camber or belly for a better cut.
Stephen
Is it in-cannel or out-cannel?
Wiley Horne--So. Calif.
Hi Jack,
Stephen Shepherd is a past master at these things. Here is his discussion of out-cannel augers:
http://www.fullchisel.com/blog/?p=103
His post immediately above is about in-cannel--either way, he's the man.
Wiley
Poor photos
Not very clear pics but it gives the general idea. The tip is rounded and shiny. I just need to redefine the shape. I think from what Stephen says I may be able to get it but a picture would be helpful. Thanks for the info.---Jack
Darrell in Oakville
Re: Poor photos
Darrell in Oakville
Jack,
I'm not sure if this is the correct type of bit or not, hard to tell from your photos. The ones I commonly find are sharpened like this:
grind it
hone it
and then use it
next challenge, figure out how to grind those twist bits with the steep angle for wood, like the bottom one here:
Darrell
Wood Hoarder, Blade Sharpener, and Occasional Tool User
feels so weird to have real shop time now that the kitchen reno is done...
Re: Poor photos
That's not it.The tip of mine is a cutting edge .The best way I can describe it is like an old style forstner bit with only one cutting edge and no spur in the center. It cuts an almost flat bottomed hole. I don't know enough about it to shape it correctly and can't find a picture of one. I'll keep searching.---Jack
Patrick Gibbons
Jack, I think you just sharpen the end so that it shaves almost like a scraper. That's the jist of what I got from The Practical Woodworker.
Ship Auger
Warren in Lancaster, PA
Jack I think you have what used to be called a ship auger. Today ship augers have a spiral twist and a flat cutting edge like yours, but in the 19th century they used to have flat cutting edge and no spur at the tip of a pod shaped auger. A little like a Jennings bit without spurs, without twist, and only one cutter. I think the cutting edge should have a little relief on the bottom (maybe 5 degrees) and a bevel on the upper side. I haven looked at one recently.
Here is a drawing from the Sheffield list, but the important parts are not clear. 424 Carpenter's shell auger, 426 Dod's pattern ship auger, 427 Long pod ship auger.
That's it
That should help.thanks---Jack
Darrell in Oakville
Re: Poor photos
Darrell in Oakville
Ahh, OK, now that I see those other pix I think I have something like that. I really do need to find a better way to store these, they are so difficult to access way in the back of that shelf that I keep forgetting I even have them. So they don't get used. *chagrin*
Some are sharp, some not so much. Shortest of these is 14 inches, longest is 18. Gah, I need a better camera than this silly phone.
Maybe you can get some idea of the cutting edge geometry from these?
Darrell
Re: Poor photos
That will help. Any idea what they called those?Looks like it may me a more modern version of mine.---Jack
Ship augers
Those are also ship augers, probably from the early 20th century. The ship augers of today have the same type of spiral shaft, but they have a lead screw. They have a single cutter like the old ones, but the edge is straight whereas I think yours and Darrel's are curved edges.
Here in Maine
Bob Hackett
Those types of augers are called barefoot augers. They were used a lot in wood boat building.
