What Have I Got?
William Duffield
My brother found me a #3 bench plane. While trying to decide what to do with it, I noticed a crack in the sole from one corner of the mouth back about 1/2". The only markings it has are "No 3" cast into the front of the toe and a tapered blade marked "BUHL". I can't see any clear indications that the blade might be cast steel or laminated, but I'm not ruling that out.
Other than the crack in the sole, and a lot of surface rust, it appears to be in pretty good shape. My idea is to repurpose the parts: The frog, blade, chip breaker and lever cap would be made into a stringing thickness scraper. Reference the one offered by Lie-Nielsen here: http://www.lie-nielsen.com/tools-for-inlay/latta-thicknessing-gauge/. This one would be larger, and more complicated than a piece of steel and two screws, but the price is right and it would be more easily adjusted. I would need to turn the blade over and regrind the bevel at about 40° to make it into a scraper. The sole could be sawed in two at the mouth, and the rear 3/4 mounted in another block of wood, charged with 0.5 micron diamond and used for sharpening. I'm sure I could find a use for the rosewood knob and tote. Any better ideas? I already have a Stanley #3 with an aftermarket blade in it that works well, so I don't need another small smoother.
As I mentioned to Jim, on a previous trip to San Jose, I found, among other rarities, a Type 1 #113.
