New WoodChat!
THE WOODRAT IS BACK!
Stanley plane
Stanley plane
Stanley plane
Jeff Habeck
I recently obtained a Stanley #5 hand plane. it is clearly a type 12, one patent date and a sweetheart logo on the blade, rosewood knob and tote. From what I've read they were made between 1919 and 1924. However, the knob is a short one like the type 11's were supposed to have, type 12 going to a taller knob. I have also read that Stanley used their existing supply of parts when changing models so this would make sense if this was made early in the type 12 run. As I have already refinished a few hand planes and plan to use them (including a later #5) I'm wondering if I should do the same to this or not. There is a small chip on top of the tote, nothing bad, but outside of that this plane is in very good shape, showing little use. Is the short knob unique? Should I just refinish this, or would that ruin it for some collector if I destroyed the patina? I do love the Brazilian rosewood knob and tote and it's a beautiful plane but if it has collector value I would hate to ruin that, rather sell it and buy a few more that I can restore and use. What do you think? Also, if anyone has stumbled on a place to buy a 12/24 tap and die set PLEASE tell me where it is. THX.
Re: Stanley plane
Re: Stanley plane
paul-in-plymouth
Surprisingly, Amazon is a good place to find individual taps, dies, letter- and number bits, and things like that. Go to Amazon and search for "12-24 tap." You'll find lots of options. You'll find fewer 12-24 dies, but still plenty of options.
Re: Stanley plane
Re: Stanley plane
Hi Jeff
My attitude is that Collector value is only attached to those items that are rare. It is rare when there are few of something, and the condition is as close to the original as possible. It is highly improbable that a Stanley #5 Type 12 is going to have any collector value - unless it was used by Elvis.
You can do anything you like to this plane. Indeed, this is a case where value is added when it is clean and rejuvenated. Use it and enjoy it!
There are some limits ...
Re: Stanley plane
Re: Stanley plane
Stuart Hough
I agree with Derek for the most part. I have three #5's, and while I have only rehabbed one fully, and one partially, they are worth a BUNCH to me. Collector value is a very fickle thing. I've seen corrugated #8's going for upward of $500 on ebay several years ago, and now they are running around 1/3 of that. I say polish it if that turns you on, or just coat it in shavings. Use it, care for it, and then pass it on when you're finished with it. That's the true value of the thing.
Re: Stanley plane
Re: Stanley plane
john sayles
JEFF
I'm going to assume you're actually looking for a 12-20 tap & die set, and not a 12/24 as you've specified(since the latter are not difficult to find, and the former are the strange configuration used by Stanley).
If so, you can find them here: http://www.victornet.com/
Re: Stanley plane
Jim DeLaney, Austintown, Ohio
Re: 5mm X 0.8
A 5mm X 0.8 tap (or die) is very close to 12-20. In fact, considering the 'slop' in the Stanley threads, it's a near-perfect fit.
Re: Stanley plane
Another tap option...
John in NM
I made bigger totes and knobs for some of my planes, years ago. I used a 1/4-20 tap to ream out the threads and used allthread for mounting the new parts.
