New WoodChat!
Finish ash chest
Finish ash chest
Finish ash chest
Svante
Hi,
Some months ago I posted a message regarding drawer clearance. I got some good advice and decided to go for somewhat less than 1/32. The doors have to have a bigger clerance - I will start with 1/16.
Now it is time to finish the chest. I normally use oil and wax based on linseed oil. It works fine but gives the wood an amber colour.
For this chest I want the ash to stay bright without getting amber coloured. Any suggestion?
Regards,
Svante
Re: Finish ash chest
Clint Searl
Clint Searl
Beautiful! Water white Cab acrylic lacquer would be my choice.
William Duffield
My recommendation would be dewaxed, superblond shellac.
You might want to follow that with nitrocelulose lacquer if you think you are going to need protection from water spills. Does the recipient carry hot coffee cups around, set them down and forget where the put them, or do they like to have potted plants all over the house? If not, forget the lacquer. It's more often used for table and sideboard tops.
Clint Searl
Clint Searl
NC lacquer lends an amber cast.
William Duffield
But not as much amber as most varnishes. The CAT lacquer you recommend is better in that regard, but is more difficult to repair. That being said, it is also more impervious to solvents than NC lacquer. There are always tradeoffs. The ash itself will also turn more brown with age and oxidation, but you will probably not notice that for many years.
Jim DeLaney, Austintown, Ohio
Re: Finish ash chest - Waterborne Lacquer
Target EM6000 or General Finishes' "Enduro" are both water clear waterborne lacquers that will provide a durable, and colorless, finish.
a poor choice
One of the first jobs I ever took was to build some ash pedestals for a gallery. I didn't know better and finished them with nitrocelulose lacquer, which turns yellow with age. After a few months in the store window the pedestals were a horrid yellow color.
I have finished lots of ash over the course of 40 years. It will not stay white. The wood will oxidize and wind up brown no matter what you put on it. But if you use a "water white" finish at least the color won't go toward yellow.
Most water based finishes are water white and stay that way. Cellulose Acetate Butyrate (CAB) lacquer is a reasonable choice too but it must be sprayed. Avoid anything oil based. All the oils yellow as well as most urethanes.
Clint Searl
Clint Searl
In practical terms, reparability of the finish is a non issue, though the solvent CAB and NC that I use, Sherwin-Williams, are practically equivalent in their physical characteristics except for color.
don stephan
Test your choice on scrap first so no surprises.
Digression
Nice design.
Svante
Thanks for input.
I would prefer to use a wipe on/wipe of finish as I am not capable of spraying.
It does not need to be a water resistent finish and I like a hand rubbed apperance.
I guess this leaves me to superblond shellac?
If I want to put wax on, what type shall I use? The one I have experience of are based on linseed oil and do yellow the Wood.
Regards,
Svante
Metric-Imperial mix-up?
Bruce McCrory
I love the angle divergence! And the sensitivity to grain and its direction in the joints is outstanding. 8)
I have a hunk of ash in my wood pile, but my only experience using it was bending for kayak ribs.
Lars Parrington
Nice work!
Maybe something with a UV blocker in it? I imagine that would help keep the underlying wood from darkening, as well as retard any yellowing of the finish itself.
The only finishes I can think of that have UV blockers added are spar varnish, and some lacquers. I don't know if a water white spar varnish exists, so maybe lacquer is the best choice.
I would try thinning the lacquer way down, and wiping it on just like shellac. After a few coats buff and wax. I would definitely try it on scrap first, since I have zero experience using lacquer as a wood finish.
Re: a couple other notes
Lars Parrington
For wax, try trewax paste wax. It doesn't change the color of the wood at all. I belive it uses hydrotreated parrafin oil (aka lamp oil) as a base. My local hardware store carries it. It looks like this.
If you go with shellac, you might try using zinser sealcoat. I used it straight from the can on this lamp. It's dewaxed. It's convenient and relatively cheap. It's pretty close to water white.
What worked for me
I once did a solid white ash dining set for a customer. It had to be really white, so I bleached it with KleenStrip A-B bleach and lacquered it. It has stayed beautifully white for about 30 years.
William Duffield
The problem with using spar varnish is that the UV blocker itself has a yellow tone.
