New WoodChat!
What is this used for Old Tool
Don Evans
I inherited lot of older hand tools and know what they are all for except this one. Anyone know what it is for: I believe it is used on round tenon's but the orientation of the blade is wrong for making the tenon its self. It may be for squaring up the top end of the tenon.
Anyone help, if it works there will be a pix, I may have to make another message for the second pix.
Don
Note in second pix you are looking at the bottom and the blade is just above the 2 screws, at bottom, one screw above the other continue up and you should see the bottom of the blade. It is at about 4 to 5 oclock if using clock face over bottom of unit.
The round knob at 10 to 11 oclock has a gear under it, when turned you can open and close down the throat.
Don
Re: What is this used for Old Tool
j mohnike
It is a hollow auger I have one, and use it all the time, however (isn't there always one) you should also have, what I call, a cone cutter. Looks like an oversized pincel sharpener, mine will accept up to 3" stock. It cuts the ends round, you stop cutting when the top of the stick is the same or just under the diamater of the tenion you want. Then you cut the tenion useing the hollow auger, at least that is how I do it.
Don Evans
Thx for the replies guys, I THINK I see how it is used now. The orientation of the blade being 90 degs to the rotation confuses me. Am I right if I say it cuts the end of a stick going down it by cutting the end NOT shaving the side of the tenon?
I think that is what is done here. Hard to put into words accurately.
Don
j mohnike
Correct
William Duffield
If you do a Google image search on "round tenon cutter" I think you will find that they all work that way. The trick is, with every pass of the blade, you sever end grain right up to the shoulder. With no support, the fiber that you just cut peels right off. It's kind of like splitting off the cheek on a square tenon after sawing the shoulder, but on a much smaller scale. Remember that these are typically used on green wood that is very straight grained, because it has been very recently been riven from a log (or is still a log).
Don Evans
Got it, thx much.
Don
