Re: Sharpening a Drawknife
TomD
That's a good sumary as always, and a useful jig, though I do expect to see it on that show about the many ways to kill oneself. It could probably feature a few times if a person really Darwined out on it.
When picking up tools that may need a referb, or when making them, some means to power grind them is always a bonus. A draw knife is such an ideal candidate for belt sanding, I tend not to move on from there. There is usually some area of slack belt where the convex shapes can be ground, and there is always the platen for regular bevels. At the extreme tools end of the spectrum, there is always this, a rotary platen:
It might at first look like a belt sander, but what it actually is, is a belt tensioned between different pulleys to provide different degrees of deflection. The grinding belt goes over the top of the stuff you see there. Cool, huh, though I don't have one, I just use regular belts.
A minimally practised hand with a draw knife can cut right to the layout lines in a few passes on a windsor spindle. In fact that is the needed technique, as the geometry is a play on cutting to squares, then octagons, then reducing the octagons to squares, in order to get the tapers. With those skills, one shouldn't have much difficulty freehanding the grind. Apparently the student who first spotted the geometry was... a student. So most people shouldn't have much trouble picking it up.
