New WoodChat!
Panel saw vibrates
Panel saw vibrates
Panel saw vibrates
Joe in a Cleveland suburb
Hello.
I have a Disston panel saw that was 'restored'. I was told it's a D8 crosscut. I picked it up a month or two ago.
I used it last night for the first time. Cuts nice. Seems to work well, but I noticed a vibration sound coming from the handle.
I checked the split nuts and a couple seemed to be a little lose. So I snugged them up a tad. Started sawing again and after a little use, it started vibrating again. So I tried to snug them a up bit more (being careful not to over do it).
I noticed the split nut in back is spinning when I try to snug them up. So, I guess it's not getting as tight as it should.
If I hold the handle and the plate, I can't move either. In other words it 'feels' tight, but it must be lose just enough to vibrate.
So, my question is, can this be corrected? Do you think a tiny bit of epoxy would help hold the nut in place?
As I recall, the nut is square where it seats in the handle, and I figure that has been rounded out not allowing the nut to hold in place.
Suggestions?
Thanks!
Re: Panel saw vibrates
Patrick Gibbons
Put wax or Vaseline on the nuts, put plastic wood compound- the stuff you knead together, into the hole and put the screw in to shape the hole. Remove screw and let the goop set. Voila, Bob's your uncle, shazaam, Great Scott, Holmes!, Bada bing Bada boom, Lawdy Miss Claudy your problem is solved.
