New WoodChat!
Blade to tight in OS smoother
Tony Wilkins
After moving from Kansas back home to the dry South Plains, the blade for my Old Street coffin smoother is to tight to fit back into the body. What is the appropriate way of rectifying the situation?
Re: Blade to tight in OS smoother
Wiley Horne--So. Calif.
Hi Tony,
If you're not in a hurry for the plane, I suggest calling Larry or Don, and asking if they will adjust the clearance for you. Then ship it to Arkansas. Reason 1: Right now, you own an Old Street plane; once you do your surgery on it, it'll be a user mod Old Street. If they fix it, it'll be restored with original finish on it, and you won't be able to see what was done. They might just grind a little off the iron. Reason 2: Those side walls are quite thin sections at the top, and beautifully sculpted--it would be easy to mung them up. Reason 3: You could ask them to comment on your sharpening, which would be very helpful to you.
It's a really nice plane.
Wiley
TomD
Wiley's ideas all have merit. One thing I would do, unless you know for sure your current situation is the problem, would be to just leave it for a while and see what happens. Even were it the case that you came from a dry place, to a wet place, and therefore a tight blade would make sense, why would two shops be any different, or the new shop could be drier. Obviously we do not all have temp and humidity control to perfection where we work.
You could find a dry place to put the plane, not crazy dry like the trunk of your car on a hot day, and let it gradually get to a place where the blade will come out. Then bring it back into your workspace, and see whether it gets too tight.
I like to take care of stuff like this myself, and Wiley is right that these planes are made a lot more "elegantly" than the norm, so you might not want to do what I probably would do, which is take a float to the thing and ease it up. Grinding the blade if you are set up for it, would then be an option, or even making a slightly smaller blade for your wet shop use. Then you are covered wherever you plane to.
Consulting the folks that made her is probably a good idea. But on the other hand. I don't know if they make planes, state by state. If you send it to them and it changes again, then they are guessing, or just doing some fairly rote thing you could do yourself. Wooden planes are not necessaries meant to be eternal in their original form and I adjust mine all the time, so I would regard sending one back as like sending a knife back to the factory to be sharpened. I say that just to make you feel comfortable with the idea that you can do this if you want to, not to make you feel that you "should".
