New WoodChat!
OT - philosophical question about the universe
Why is that, when you are working on a project*, any piece of hardware that you drop** invariably rolls into the most inaccessible location*** rather than out where it can easily be picked up?
*For instance, say, installing new shades for your sweetie while standing on her desk at the end with the bookcase next to it.
**For instance, say, the screw for the bracket.
***For instance, say, behind the bookcase next to the desk.
Thank goodness it's an old oak business desk, with legs, rather than a design that goes all the way to the floor; a bit of crawling and cussing, and I was back in business.
Re: OT - philosophical question about the universe
BrianMonumentCO
No doubt about it this covered thoroughly under the doctrine of Murphy's Law.
There are many corallaries, One covers your exact circumstance.
The corollary that covers it....
Wiley Horne--So. Calif.
'Inanimate objects are out to get us'.
Wiley
I've got one... from Friday night...
John in NM
The unloader valve on the air compressor here at work was blowing off all the time, so the compressor ran every 15 min or so. By the next day it had stopped leaking (we're replacing the check valve anyway).
Why doesn't my stuff fix itself? >(
Kevin French
I think you've just proved the theory of 'Dark Matter'.
Jim Toews
Your comment brought this to mind. I first came across it in Chris Schwarz' blog.
Resistentialism is a jocular theory to describe "seemingly spiteful behavior manifested by inanimate objects",[1] where objects that cause problems (like lost keys or a runaway bouncy ball) are said to exhibit a high degree of malice toward humans. The theory posits a war being fought between humans and inanimate objects, and all the little annoyances that objects cause throughout the day are battles between the two. The term was coined by humorist Paul Jennings in a piece titled "Report on Resistentialism", published in The Spectator in 1948[2] and reprinted in The New York Times;[3] the word is a blend of the Latin res ("thing"), the French resister ("to resist"), and the existentialism school of philosophy.[4] The movement is a spoof of existentialism in general, and Jean-Paul Sartre in particular, Jennings naming the fictional inventor of Resistentialism as Pierre-Marie Ventre. The slogan of Resistentialism is "Les choses sont contre nous" ("Things are against us").
Steve Voigt
Awesome! I'm totally a resistentialist.
What I want to know is, what happens to the things you drop that actually disappear, never to be found again. Do they vanish into the ether? Are they teleported away?
Working in a machine shop years ago, I once dropped all the ball bearings out of a customer's part. I still have nightmares.
wilbur
Entropy.
JDK
To quote that great philosopher Forrest Gump: "S**t happens."
Dave T
The parts you drop and can't find go to the same alternate universe where half of all the socks go (there's obviously a portal in the dryer). Sometimes you can bring them back, but only by purchasing a replacement and either opening the package and/or losing the receipt...in other words, once you're committed to the replacement....then the original parts will reappear.
You only dropped it once?
Bruce McCrory
My problem is the second time it finds a new, harder place to access. Unless I put the furniture back.
BrianMonumentCO
Not to diminish the complete explanation of such occurances by Murphy's Law but this may be a conspiracy between objects that can get lost and those that can help with them hiding or being lost.
Such objects include any piece of furniture large enough that you need help moving it, any object that has wheels under it, and any object that is like insulation where things can hide.
That is just partial list of the conspirators.
There are also a group of facilitators such as springs. As a gunsmith I can well tell of many times when a small hard to find part will get launched into what I refer to as a low earth orbit.
At gunsmith school I had an opportunity to witness the conspiracy committed by a gunsmith with butter fingers, a spring, a large flat clean surface (excellent for the high speed getaway of a small part, and a cooperative drill press that concealed the run away part. I was standing at the mill and witnessed the last part of the escape as the small part hid under the drill press.
That's why if I need 8 screws and they come in
Chuck Nickerson
packs of 6, I don't complain; I just buy two packs.
Re: OT - Basic Physics
TomD
I am a large object, therefore I am located in open space. I can't fit in the crack behind a desk. When things are dropped, particularly rounded things, they tend to keep moving after they hit the floor. Since I am already in the open space, probably facing the tight space, dropped objects tend to become less accessible as they roll from open space, and come to rest against objects like the wall, under a desk. Most of the fix-it action occurs against walls, etc... I can't hang a picture in the open air in the middle of the room. So you are pointing in a bad direction when most stuff gets dropped.
The good news is that we have the Dollar store, and they have reasonably priced force multipliers like magnetic probes, and magic hands. Also very important is an LED flashlight with which you can illuminate these mysterious realms. As a mess rat, one of my great innovations is to never look for anything without an LED light in my hand. Doubles the chance of finding stuff. They even carry a magnetic probe with an LED light in the magnet. Though it is a little bulky. So far I haven't seen a magic hand with an LED in it.
Darrell in Oakville
The Reclacitrance of Inanimate Objects
Darrell in Oakville
I know this well.
The best (worst?) one was a dropped screw, an irreplaceable part of some complex gadget I was working on. I dropped it, and it vanished. I checked the floor. I cleaned the floor. I widened the search. I scoured the entire shop, several times over, to no effect. SWMBO, growing curious about the continued and escalating mutterings emanating from the shop, came to see what the problem was. I explained the missing screw and my efforts to find it. She looked at the bench, peered at the face vise, reached in and delicately plucked the missing screw from it's precarious perch atop one of the guide rods. AUGH!! It FELL there and stayed! I could not balance it on there if I tried (and YES I did try!!).
Nowadays I try to be more open minded about where lost items can get to...
Darrell
Wood Hoarder, Blade Sharpener, and Occasional Tool User
Re: That's why if I need 8 screws and they come in
BrianMonumentCO
Then you have extras when they escape under that large immovable object.
Re: The Reclacitrance of Inanimate Objects
BrianMonumentCO
That may be one of the final steps in the proof that inanimate objects are at war with us allegedly thinking beings. But yet those items are ultimately ruled by Murphy's Law.
There must be some kind corallary to Murphy's Law that applies to the 2nd searcher.
Something along the lines of after one has searched so long and hard the searcher must have missed many hiding places where inanimate objects can go that another searcher starting from scratch will find it.
This of course could also show that the inanimate objects are mentally connected to the person who dropped them.
R Goldman
The benefits of screws with octogonal heads. Jerry Glaser created turning tools with octogonal handles so they wouldn't roll off the bench.
BrianMonumentCO
A truely deviant part will get a running start and still roll into an less visible or inaccessible location.
It is part of their plan.
