New WoodChat!
Homemade Filler For Small Cracks
Tom Colligan
What's a good brew to mix with fine saw dust when you need to fill small cracks in a project?
Years ago Duco Cement was recommended; Watco Danish Oil mixed with the saw dust has also been recommended though this mixture takes quite a while to firm up.
What has worked for you? Thanks,
Re: Homemade Filler For Small Cracks
Howard Pollack
Whatever you're using for finish mixed with sawdust (fine) from the project you're working on. -Howard
Guillaume Dery
I've used epoxy as a grain filler when doing French polish to good results. Ought to work for cracks too although I haven't had occasion to use it like that
GD
TomD
There really isn't one good go to solution. The reason is that many wood dusts will make a mixture that is much darker than the parent wood, so simply mixing those woods with whatever is not going to be successful in many cases.
The single best all around filler for small blemishes will be dust and super glue. Hot shot being the most commonly mentioned variety, but other types work. You can sand the surface to be treated so that the dust fills the crack, then hit it with glue. This does work really well sometimes, but often you end up with the dark crack look. Or you end up with a whitening of the glue. Alternative 2 is to hit the crack with the glue then sand over top of the crack. This usually works better, but a certain amount of skill is required since it can be the case that you get stuck to the work, fail to fill, etc... But it tends to hide blemishes better.
Then there are woods like cherry that tend to have dark inclusions, so there, I use black epoxy that I make out of epoxy mixed with graphite powder. Black epoxy from the supplier often has a rubbery base. I mix my stuff first, then apply, this seems to protect the wood from just getting all smudged black.
If you want to do this really well, you need to do samples and stuff, so as to ensure that the results are predictable.
So rather well known people who "french polished" for a living, were actually using mostly a 5 min epoxy finish. This is a good deal from one perspective since if it was good enough for them... On the other hand there is some crazy stuff you can get away with using french polish that one would never consider with any other material. Stuff like filling surfaces by polishing across the grain with course pumice, and non-drying oil.
craigd
craigd
If the crack is big enough to hold rasp/file/coarse dust I use liquid hide glue. I used to use epoxy, but LH has worked just as well and is a lot more pleasant to work with. Plus, it does take finish so it will blend a bit better than epoxy; I think it is a bit more "natural" looking but if you are looking, you will see it.
craigd
craigd
As an example, there is gallons of LH/dust in this stool as the branches it was made from cracked like crazy.
John Veerkamp
I usually use CA glue in my turnings. The tone even if darker looks fairly natural. To avoid the super glue staining the wood around, seal the area around the repair with lacquer or shellac. Do your repair and when dry sand the entire area lightly.
If you have some time, I also like
Wiley Horne--So. Calif.
liquid hide + sanding or file or scraper or rasp dust. Get a pile of dust first. Then a little glue in the vicinity of the place you're filling; make a wet slurry of the glue/dust mix and work it in--I like to use a flexible scraper for all of this, making the dust, making the slurry, working it in, and leveling it. As said, the glue will not affect finished color at all. The glue is particularly good (obviously), if you're on a seam that will benefit from glue.
But. The glue is water based. The area will swell some. It's best to give it overnight time to dry and get back to normal. If you come in too soon to scrape or plane for final finish, the area can keep shrinking and go 'below grade', and then you will have a visible line.
So. Another alternative….If in a hurry, you can do the above with blonde shellac. It will not cause swelling to speak of, and dries very quickly ready to work.
Finally, Behlen's repair kit using shellac sticks and a burn-in tool is a great thing IMO. It will make invisible repairs, once you practice enough to match the shellac to the area, including blending the shellac or creating a little variation within the repair area to make it look natural.
Wiley
Same here...
John in NM
Hide glue and rasp filings. Dust seems too fine to me, but with hide glue I doubt it would matter much. The hide glue binder doesn't darken like some of the other options. It does shrink though, that can be a problem.
The other one I've tried for dents and dings is glazing putty with paint for color. A universal colorant should work too, but the putty is stiff enough that you have to knead by hand, and I'd rather use paint for that - oil based paint btw, like Testors model paint. You can even approximate some of the grain patterns by making little rolls of darker or lighter putty and pressing them into the fill and smoothing some. I don't know how it holds up over the years, but should be as good as or better than commercial fillers. I do know that using this technique I did once "lose" the ding, couldn't find it again the next day - pretty good :D
Couple things
I'm not sure how you're defining small cracks. For hairline cracks, epoxy and dust always worked for me, although I usually used a lighter-colored wood species to make the dust because of the darkening effect of the glue. For patching ebony and rosewood, you need to be careful when preparing your dust, to make sure there aren't any light-colored specks in there.
For bigger patches, I prefer a non-shrinking water-based wood filler like Elmer's carpenter's wood filler, tinted with universal colors to match the tone of the wood. To make any patch nearly invisible, you can match the surrounding grain with a tiny red sable brush, dipped in lacquer or shellac and then in fine pigment powders.
