Depth Micrometer
Brian Greene
I found a lufkin 513 today. I'm not sure how it works. Should the large knurled barrel move/lock separately from the smaller knurled knob at the end?
Thanks
Depth Micrometer
Brian Greene
Thanks
Re: Depth Micrometer
Wiley Horne--So. Calif.
Hi Brian,
On a width micrometer, the knob at the end ratchets, free of the knurled section. Its purpose is to allow the user to close the micrometer on the object with the same closing force each time. The closing force is simply the click-pressure of the ratchet, and you're using the ratchet to close the micrometer.
I'm guessing it's the same for the depth micrometer, except it's the bottoming pressure that is established by the ratchet click.
Wiley
Joe Rogers, Northern Virginia
The thimble of a mic may or may not be ratchet equipped. Some mic's do have a ratchet thimble. Some have the large portion of the thimble built with a slip function, some are all one piece and the small end is a "speed adjust" portion. It depends on the part # of the mic. I prefer the ratchet thimble as I don't use a mic often enough to develop my calibrated feel.
Joe
