New WoodChat!
200+ woodworking book reviews
What screws should I use to affix
Wiley Horne--So. Calif.
Hardiebacker board to subfloor? Do you use a drywall screw? I want the screwhead to carve out enough backer board to sit flush.
Thanks,
Wiley
Re: What screws should I use to affix
I think there are specific screws for the job that carve out their own countersink. Talk to the company from which you're getting the Hardibacker.
Guillaume
Haven't used the HardieBacker per se but I have always used drywall screws to affix cement board. Using an impact driver, you can definitely get them to countersink themselves flush or even be a bit under the surface (preferable). Being anal retentive, I usually go over the screws themselves with thinset at the same time that I tape my joints. This lets you fill in any screwups if you ended up overdriving a screw and cracking. Going over the screw holes with the thinset gives you a surface adequate for painting on waterproofing membrane.
Short answer, drywall screws are fine for cement board.
Guillaume
P.S. If you haven't already, pick up a super coarse diamond rasp. They are the cat's meow for cleaning up and smoothing your cut edges on the cement board as well as your tile. They usually have them in the tile section at the BORG for about $20
Paul in NJ
Hi Wiley,
In the big box stores they are in the same area as the Hardibacker. The screws are coated for rust resistance and have a little nib under the head that cuts a countersink as you drive it.
Paul Dzioba
Jack Guzman from Maine
I use the special coated screws that were designed for use exclusively with that material. Before I knew about them I always used galvanized roofing nails. The large flat head lies flush and doesn't interfere with the tile installation and they grip the subfloor well.Drywall screws are not a good choice for that application.---Jack
Brian Greene
There are special coated screws for cement board. Drywall screws are not recommended.
Guillaume Dery
Brian,
Once you apply the waterproofing membrane, corrosion becomes a non-issue. Hence my recommendation., else, yes get coated screws
Thanks all!
Much appreciate the good advice. I'll order the Backer-On #10, 1-1/4" screws for the 1/4" backerboard. Was hoping for an alternate, as I don't need 800 of 'em (which is how they're offered). Guillaume, I have no doubt you've made good installations with the drywall screws, and I will definitely get the supercoarse diamond file.
Wiley
Re: Thanks all!
Wiley,
Homedepot.com lists a 150 pack.---Jack
